Analytics Management
The Analytics function in Manager provides dynamic, real-time charts and exportable data that provide insights into your content usage.
You can use parameters such as folders, users, dates or roles to generate an analytic specific to your needs.
You can also save search filters on any analytics report. Once the search filter is saved, you can then select that filter within the report to save time when you need to run the report again.
The analytics reports are:
Best practices
  • To save both chart and data report information to a PDF, use the Print function and print the report to a PDF printer type.
    Note: The 'Export to PDF' function does not save the chart in the export file. Only printing to a PDF will save the chart.
  • Run the Inactive users report periodically to see who is not using the Panviva knowledge base. It allows you to take corrective actions for struggles the user may be having.
  • Run the Top search terms report periodically to see what users are searching for. In team huddles, ask if the search results brought the user(s) what they needed. You can then take corrective action to add text or keywords to documents if necessary.
