Run Search trends
  1. Open Panviva Manager An administrative role responsible for managing workflows, feedback, and document assignments..
    The Document Management window displays.
  2. Click Analytics.
    The Analytics window displays.
  3. Select Search trends.
  4. Complete the fields, as required.
    Field
    Instruction
    Search term
    Type the term to search.
    Search type
    Select Normal and/or Autocomplete A predictive search feature that suggests documents after the user types at least three characters in the search field..
    Users
    Optional.
    Select a user or users to narrow your search.
    Roles
    Optional.
    Select a role or roles to narrow your search.
    Date from
    Select the start date.
    Date to
    Select the end date.
    Note: If the time interval selected is long, then the chart displays an appropriate interval that may not be the same as that selected. For example, if the date range is more than a year, then only weekly or monthly data points display to ensure the chart is readable.
    Time interval
    Select Daily, Weekly or Monthly.
  5. Click Run analytics.
    A chart displays with your results.
    Note: Hover over a data point to see the date and active user count. Scroll down to see more details.
To toggle between chart and data views:
To see the...
Then...
Chart view
  • Click .
The view scrolls to the chart.
Table view
  • Click .
The view scrolls to the table.
To zoom in on an area of the chart:
  1. Press and drag over the area of the chart you want to examine in more detail. Hint.
  2. Click Reset zoom to return to the original setting.
  3. Choose the next step:
    To...
    Then...
    Print the report
    Click Print
    Export the report as a PDF
    Click Export to PDF
    Export the report as an Excel spreadsheet
    Click Export to Excel
    Export all of the analytic's data as a CSV
    • Click Export full data
    The report runs as a background task.
    • Click More menu .
    • Select Background tasks.
    • Select the report.
    • Click Download.
  4. Click Reset filters to run a new report.
To save a search filter:
You have applied filters to an analytic report and you want to use those same filters again in the future.
Note: You can save multiple filters for any analytics report.
  1. Click Save As. The Save Filter As dialog box displays.
  2. Enter a Name for the search filter.
  3. Click Save .
The filter is listed in the Saved filters field.
Note: The next time you run this analytic, you can select the filter and the filters you had applied populate the fields. You can then click 'Run analytics'.
To use a saved search filter:
  1. Select the appropriate Analytics report.
  2. Select a saved filter. The appropriate fields populate with the saved filters.
    Note: You may still add or change filters as needed.
  3. Click Run analytics. The analytics report displays.
