Manage notes
You can create and manage personal notes in documents. This section details the steps to add, view and delete notes in a Panviva document.
Note:
Open a document in Viewer.
Click More
Select Actions >
Add a note.
The Add note dialog box displays.
Type a note.
Note: The maximum characters is 3,000.
Select Add Note.
To view your note, click
Notes at the bottom of the toolbar.
Your note(s) associated to that document will appear.
Click
Notes at the bottom of the window.
Your notes associated to that document displays.
Click Delete.
The "Are you sure you want to delete this note?" dialog box displays.
- Click Delete Note.
The selected note is removed.
Note: If this is the only note, the 'Note' icon is also removed.
If a Notes dialog box displays:
There are no notes on the document.
To... |
Then click... |
Add a new note |
Add new note |
Return to the document |
Close |
