About Lookup Manager Component
The Lookup Manager component determines the correct recipients for faxes sent to DID/DTMF extensions. This component uses Windows 2000 Active Directories to find matches in the recipient's record (in the Fax field on the Phone/Notes tab) in the Microsoft Exchange Server Administrator.
The Lookup Manager component can route faxes to multiple users that all share the same extension number. For example, if one DID extension is assigned to five users, the Lookup Manager component routes all faxes destined for that DID extension to all five users.
Tip: Each connector that uses Lookup can use a different Lookup server and search criteria. You can configure these properties in the specific connector's properties.
You can have up to four instances of this component. You should not modify its settings unless Technical Support instructs you to do so.
Configuring Lookup Manager Component
