Activating a License
You can activate the Upland AccuRoute license in one of two ways.
  • Automatically - when you enter an activation code and the server is on a system that has access to the Internet.
  • Manually - if the server does not have access to the internet. In this case, you will:
    • Submit and validate the activation code.
    • Create an Export file into where the activation code is copied.
    • Create an Import file and use this file for activation from a system that does have Internet access.
About Server License Key
Changing the License Key
