Adding a SMTP Connector
Before you add the connector, review the Windows SMTP documentation. In most cases the default settings are sufficient to support SMTP connectivity with the Upland AccuRoute server. You must also configure a virtual SMTP server.
  3. Right-click Connectors. Select New Upland AccuRoute connector > SMTP . The License dialog box appears.
  4. Type the license number.
  5. Click OK. The Server Address dialog box appears.
  6. Click Next. The Display Name dialog box appears.
    Alternately, if you want the connector to run on a remote server, click Remote Server and type the server name. Click Next.
  7. In the Name box, type an appropriate name.
  8. Click Next. The Congratulations dialog box appears.
  9. Click Finish. The SMTP Connector is listed in the details pane.
Configuring virtual SMTP server properties
You can configure the virtual SMTP server properties by using the Administrative Tools > Internet Services Manager.
To configure the virtual SMTP server properties
  1. Click Start > Administrative Tools > Internet Services Manager. The IIS Manager console opens.
  2. Expand the console tree.
  3. Right-click Default SMTP Virtual Server.
  4. Select Properties.
  5. Click Delivery and Advanced.
  6. In the Smart host box, enter the address of the SMTP server. For example: smtpserver.companyname.com
  7. Click OK.
  8. Click OK to save your changes.
Sending SMTP Connector Outbound Messages
Configuring SMTP Connector DID/DTMF Lookup
Additional SMTP Connector Server Lookup Configurations
Configuring SMTP Connector Default Recipient Type and Outbound Rules
