Adding the Worksite Web Extension
Administrators can add the Worksite Web Extension to the WebApps > Default profile by using Configuration > WebApps on the Server Administrator tree. You must upload the Worksite Web Extension zip file to the iManage Control Center after adding the Worksite Web Extension.
To add the Worksite Web Extension
  2. Expand the Server Administrator tree, if necessary.
  3. Select and expand Configuration, if necessary.
  4. Select WebApps . The WebApps profiles appear in the details pane.
  5. Right-click the Default profile. The Properties shortcut menu appears.
  6. Select Properties. The Default Profile Properties dialog box appears.
  7. Select the Features tab.
  8. Select the Add button arrow. The Add drop-down list appears.
  9. Select WorksiteWebExtension. The WorksiteWebExtension Feature Properties dialog box appears.
  10. Specify the following parameters.
    • Worksite URL
    • Worksite Server
    • Format
    • Create Placeholder when Profiling (optional)
Note: The Create Placeholder when Profiling option must be selected if you want to use the Document number and ID template variables on routing sheets.
  1. Select the Generate Extension Configuration File button. The Save As dialog box appears.
  2. Save the WorksiteWebExtension zip file.
  3. Click OK on the WorksiteWebExtension Feature Properties dialog box.
  4. Click OK on the Default Profile Properties dialog box.
Uploading the Worksite Web Extension zip file to iManage Control Center
  • Find the Worksite Web Extension zip file and upload it using iManage Control Center.
See the iManage Control Center > Upload Package dialog box example below.
See iManage Control Center for more information.
About WebApps and iManage Work Web Integration
