Additional Exchange Connector Lookup Configuration
An additional lookup configuration option is available in the Exchange connector properties. Depending on your lookup configuration, this option must be enabled or disabled in order for the connector to perform lookups successfully.
To configure the Exchange connector lookup
  1. Open the Exchange connector Properties page.
    • Start the Server Administrator.
    • On the Server Administrator tree, click Connectors. All the connectors in your environment are listed in the Connectors details pane.
    • Double-click Exchange connector in the details pane to open the Properties page.
  2. Click the DID/DTMF lookup.
  3. Select a search base from the list and click Properties. The LDAP Properties page opens.
  4. Go to the Logon section.
    • If User is selected, look at the Username field. If this field contains a user ID formatted using the Active Directory logon format (for example, username@server.forest.domain.com), lookups in this search base should be successful with no additional configuration. If this field contains a user ID in any other format (for example, domain\user), select Bind using Windows generic security services.
    • If Anonymous is selected, no additional configuration is required for this search base.
  5. Click OK to save the lookup configuration.
  6. Repeat Steps 2 through 5 for all search bases in the list, and then continue to the next step.
  7. Click Sender lookup.
  8. Select a search base from the list and click Properties. The LDAP Properties page shows the Connection tab.
  9. Go to the Logon section.
  10. Click OK to save the lookup configuration.
  11. Repeat Steps 7 through 10 for all search bases in the list, and then continue to the next step.
  12. Click Recipient.
  13. Select a search base from the list and click Properties. The LDAP Properties page shows the Connection tab.
  14. Go to the Logon section.
  15. Click OK to save the lookup configuration.
  16. Repeat Steps 12 through 15 for all search bases in the list, and then continue to the next step.
  17. Click OK.
About Exchange Connector Sender Lookup
Configuring Exchange Connector DID/DTMF Lookup
