Archiving Database Field Names List
The following table lists database field names associated with archiving.
Field name
Description
ArchiveDate
Date and time when a message was archived.
COUNT_PAGES_RECEIVED
Total number of pages in the inbound message, including cover pages if applicable.
COUNT_PAGES_SENT
Total number of pages in the outbound message, including cover pages if applicable.
FAXCENTER_ROUTED_BY
FaxCenter operator the Fax was routed by
FAXCENTER_ROUTED_TO
Name of the final recipient when an inbound message was routed from the server to FaxCenter and then to the final recipient.
MessageContents
Contents of the inbound message. Company message will be compressed in a ZIP file and stored as binary data in the database.
This field is required in the database associated with the Maintenance component if you are storing the files directly into the database. It is not required if you are storing the documents in a folder share.
MessageBodyPath
Path to the folder where the inbound message has been stored. (Company message will be compressed in a ZIP file.)
This field is required in databases associated with the Database connector and the Maintenance component.
PAGES
Pages that were routed by the FaxCenter Operator
prAccessCode
Access code associated with an outbound message.
prBillingCode
Billing code associated with an outbound message.
prConceptuallyInbound
Indicates whether the message is inbound or outbound.
prDateDelivered
Date when the server delivered the message to the recipient.
prDateRouted
Date the fax was routed by FaxCenter
prDateSendAfter
Date when the server attempts to deliver the message.
This value is significant when the sender of the message requested a delay in delivery.
prDateSubmitted
Date the message was submitted to the server for processing and delivery.
prDestination
Recipient address specified by the sender.
prDestinationLocalized
Destination of the message after the address was "localized" by the Dispatch component.
prFinalFormCode
Format of the final document: G4.TIF, G3.TIF, TEXT.PDF, or PDF
prFinalState
Numerical code that represents the final state of a message.
prFinalStateError
Numerical code that represents the error causing the message to fail.
prFinalStateText
Final state of the message. For example: Delivery
prFinalStatus
Numerical code that represents the final status of a message.
prFinalStatusText
Final status of a message within its final state. Company final status might be: Successful or Failed
prJobID
Job ID number of the message on the server.
prLanguageIdentifier
Language of the message. This value will be represented by the appropriate country code.
prOmtoolServerVersion
Version of the server that processed the message.
prOriginator
Identity of the sender. Company value in this field might be an e-mail address, fax address, or other identification.
prOriginatorANI
Caller ID of the original message sender.
prOriginatorCSI
Identity of the fax board channel that received the inbound fax.
prOriginatorType
Numerical code that represents the type of originator. (e-mail, fax, etc.)
prPriority
Priority of the message as specified by the sender. This value can be High, Normal, or Low.
prProviderTSI
Identity of the fax device that sent the inbound fax.
prRecipientID
Job ID number of the message delivered to a recipient.
prRoutingParentRecipientID
When an inbound fax gets routed to FaxCenter and then to a recipient, this is the job ID number of the original inbound message.
prRecipientType
Numerical code that represents the type of recipient. (e-mail, fax, etc.)
prTemplateFilename
Filename of the cover page template that was sent with this message.
prViewedByWebSite
Integer field that indicates whether a message was routed from FaxCenter. Possible values are 1 if the message was routed from FaxCenter or 0.
RECIP_ASSISTANT_NAME
Name of the recipient's assistant.
RECIP_ASSISTANT_PHONE
Telephone number of the recipient's assistant.
RECIP_BUSINESS_ADDRESS
Address of the recipient's business.
RECIP_BUSINESS_CITY
City of the recipient's business.
RECIP_BUSINESS_COUNTRY
Country of the recipient's business.
RECIP_BUSINESS_FAX_PHONE
Telephone number of the recipient's fax machine.
RECIP_BUSINESS_NAME
Name of the recipient's business.
RECIP_BUSINESS_PHONE
Business telephone number of the recipient.
RECIP_BUSINESS_PHONE2
Secondary business telephone number of the recipient.
RECIP_BUSINESS_STATE
State where the recipient's business is located.
RECIP_BUSINESS_STREET
Street address of the recipient's business.
RECIP_BUSINESS_ZIPCODE
Zip code of the recipient's business address.
RECIP_COMPANY
Company name associated with the recipient.
RECIP_CUSTOM1
RECIP_CUSTOM2
RECIP_CUSTOM3
RECIP_CUSTOM4
RECIP_CUSTOM5
RECIP_CUSTOM6
RECIP_CUSTOM7
RECIP_CUSTOM8
RECIP_CUSTOM9
RECIP_CUSTOM10
Custom variables associated with the recipient.
RECIP_DEPARTMENT
Department associated with the recipient.
RECIP_EMAIL
E-mail address of the recipient.
RECIP_EMAIL2
Secondary e-mail address of the recipient.
RECIP_EMAIL3
Tertiary e-mail address of the recipient.
RECIP_HOME_ADDRESS
Home address of the recipient.
RECIP_HOME_CITY
City of the recipient's home address.
RECIP_HOME_COUNTRY
Country of the recipients home address.
RECIP_HOME_FAX_PHONE
Telephone number of the recipient's home fax machine.
RECIP_HOME_PHONE
Number of the recipient's home telephone.
RECIP_HOME_PHONE2
Number of the recipient's secondary home telephone.
RECIP_HOME_STATE
State of the recipient's home address.
RECIP_HOME_STREET
Street address of the recipient's home.
RECIP_HOME_ZIPCODE
Zip code of the recipient's home address.
RECIP_INITIALS
Initials of the recipient.
RECIP_JOB_TITLE
Job title of the recipient.
RECIP_MAILING_ADDRESS
Mailing address of the recipient.
RECIP_MAILING_CITY
City of the recipient's mailing address.
RECIP_MAILING_STATE
State of the recipient's mailing address.
RECIP_MAILING_STREET
Street of the recipient's mailing address.
RECIP_MAILING_ZIPCODE
Zip code of the recipient's mailing address.
RECIP_MANAGER
Name of the recipient's manager.
RECIP_MOBILE_PHONE
Telephone number of the recipient's mobile telephone.
RECIP_NAME
Name of the recipient.
RECIP_NETMEETING_ALIAS
Alias of the recipient's NetMeeting account.
RECIP_NETMEETING_SERVER
Server of the recipient's NetMeeting account.
RECIP_NICKNAME
Nickname of the recipient.
RECIP_OFFICE
Office of the recipient.
RECIP_OFFICE_LOCATION
Location of the recipient's office.
RECIP_OTHER_FAX_PHONE
Telephone number for the recipient's alternate fax machine.
RECIP_OTHER_PHONE
Alternate telephone number for the recipient.
RECIP_OTHER_ADDRESS
Recipient's alternate address.
RECIP_OTHER_CITY
City of the recipient's alternate address.
RECIP_OTHER_STATE
State of the recipient's alternate address.
RECIP_OTHER_STREET
Street address of the recipient's alternate address.
RECIP_PAGE_PHONE
Telephone number of the recipient's pager.
RECIP_PROFESSION
Profession of the recipient.
RECIP_TITLE
Formal title that precedes the recipient's name.
RECIP_WEBADDRESS
Web site address of the recipient.
SENDER_ASSISTANT_NAME
Name of the sender's assistant.
SENDER_ASSISTANT_PHONE
Telephone number of the sender's assistant.
SENDER_BUSINESS_ADDRESS
Address of the sender's business address.
SENDER_BUSINESS_CITY
City of the sender's business address.
SENDER_BUSINESS_COUNTRY
Country of the sender's business address.
SENDER_BUSINESS_FAX_PHONE
Telephone number of the sender's fax machine.
SENDER_BUSINESS_NAME
Name of the sender's business.
SENDER_BUSINESS_PHONE
Telephone number of the sender's business phone.
SENDER_BUSINESS_PHONE2
Telephone number of the sender's secondary business phone.
SENDER_BUSINESS_STATE
State of the sender's business address.
SENDER_BUSINESS_STREET
Street address of the sender's business address.
SENDER_BUSINESS_ZIPCODE
Zip code of the sender's business address.
SENDER_COMPANY
Company name of the sender.
SENDER_CUSTOM1
SENDER_CUSTOM2
SENDER_CUSTOM3
SENDER_CUSTOM4
SENDER_CUSTOM5
SENDER_CUSTOM6
SENDER_CUSTOM7
SENDER_CUSTOM8
SENDER_CUSTOM9
SENDER_CUSTOM10
Custom fields pertaining to the sender.
SENDER_DEPARTMENT
Department of the sender.
SENDER_EMAIL
E-mail address of the sender.
SENDER_EMAIL2
Secondary e-mail address of the sender.
SENDER_EMAIL3
Tertiary e-mail address of the sender.
SENDER_HOME_ADDRESS
Home address of the sender.
SENDER_HOME_CITY
City of the sender's home address.
SENDER_HOME_COUNTRY
Country in the sender's home address.
SENDER_HOME_FAX_PHONE
Fax number of the sender's home fax machine.
SENDER_HOME_PHONE
Number of the sender's home telephone.
SENDER_HOME_PHONE2
Number of the sender's secondary home telephone.
SENDER_HOME_STATE
State of the sender's home address.
SENDER_HOME_STREET
Home street address of the sender.
SENDER_HOME_ZIPCODE
Home zip code of the sender.
SENDER_INITIALS
Initials of the sender.
SENDER_JOB_TITLE
Job title of the sender.
SENDER_MAILING_ADDRESS
Company mailing address of the sender.
SENDER_MAILING_CITY
City associated with the sender's mailing address.
SENDER_MAILING_STATE
State associated with the sender's mailing address.
SENDER_MAILING_STREET
Street address of the sender.
SENDER_MAILING_ZIPCODE
Zip codes of the sender's mailing address.
SENDER_MANAGER
Name of the sender's manager.
SENDER_MOBILE_PHONE
Telephone number of the sender's mobile phone.
SENDER_NAME
Name of the sender.
SENDER_NETMEETING_ALIAS
NetMeeting alias of the sender.
SENDER_NETMEETING_SERVER
NetMeeting server of the sender.
SENDER_NICKNAME
Nickname, or alias, of the sender.
SENDER_OFFICE
Office of the sender.
SENDER_OFFICE_LOCATION
Location of the sender's office.
SENDER_OTHER_ADDRESS
Secondary address of the sender.
SENDER_OTHER_CITY
City of the sender's secondary address.
SENDER_OTHER_FAX_PHONE
Telephone number of the sender's secondary fax machine.
SENDER_OTHER_PHONE
Secondary telephone number of the sender.
SENDER_OTHER_STATE
State of the sender's secondary address.
SENDER_OTHER_STREET
Street address of the sender's secondary address.
SENDER_OTHER_ZIPCODE
Zip code of the sender's secondary address.
SENDER_PAGE_PHONE
Telephone number of the sender's pager.
SENDER_PROFESSION
Profession or job title of the sender.
SENDER_TITLE
Title of the sender. (Mr., Ms., etc.)
SENDER_WEBADDRESS
Web site address of the sender.
SUBJECT
Subject of the message being archived.
TIME_CONNECT
Time elapsed while a fax was being transmitted over a telephone line.
About Maintenance Component
About Archiving
About Cleanup
