Configuring Group Access Folders
In order for users to access configured folders, the Groups node must already be configured.
Launch the Server Administrator, expand the tree view, and click Configuration > Groups.
Right-click the group of interest and select Properties. The Groups Properties screen appears.
In the Folders tab, select Enable members of this group to select the specified Folders.
Select the folders of interest from those configured and click OK.
Removing access to a folder
You can remove access to a folder by using the Server Administrator > Configuration node.
To remove access to a folder
In the right pane, double-click on the Default group (or applicable group). The Group Properties page appears.
Click the Folders tab.
Deselect the folder you need to remove and click OK.
