Managing Fax Properties
By modifying the properties of the Telco connector, you can configure options for fax channels.
Modem properties
Options for modem properties include:
Detecting channels on a fax board
Using custom dialing rules
Modifying the top line, or header, of outbound faxes
Channels
Options for channels include:
Selecting the run mode for a channel as normal, send only, or receive only
Specifying the CSI/TSI value for a channel
Configuring a channels' receive properties to capture DTMF digits, use DNIS, use a DID lookup mask, and accept partially received faxes
Setting the number of seconds for timeout, number of busy retry attempts, interval between busy retry attempts, and the number of minutes the channel should wait for a dial tone.
Using a dialing rule and specifying the characters that the channel allows in dialing strings.
Configuring the channel to resend partial faxes
Configure the channel not to send faxes to a fax number that is being dialed by another channel
Tip: Using the modem status feature, you can check the status of all channels associated with the Telco connector.
Telco connector properties
You can also modify the following Telco connector properties.
- Change the connector name
- Enable or disable the connector
- Modify the connector profile
- Modify the path to the Telco share directory
Modem Server Telco Connector Benefits
