Routing Rules Action List
The following table lists the actions for a routing rule.
Action
Use
Description
FaxCenter
inbound, outbound
Route the message to FaxCenter. You can specify a particular FaxCenter user or all FaxCenter users.
Route to Connector
inbound, outbound
Route the message to a connector associated with the server. If you select this action, you will be presented with a list of available connectors for this action.
Route to Embedded Directive Manager
inbound, outbound
Route the message to the Embedded Directive Manager.
The Embedded Directive Manager can search the message for an Embedded Directive, apply a particular Embedded Directive to the message, or apply the Embedded Directive specified by the control file associated with the message.
Route to Lookup Manager
inbound
Route the inbound message to the Lookup Manager component.
The Lookup Manager component will query the search bases you have provided, and match the DID extension or DTMF tones with a recipient.
Silently fail message
outbound
Fail the outbound message silently when the criteria for the routing rule have been met.
Managing RuleSets
Routing Rules Criteria List
