Sending to an FTP(S) Destination on an HP MFP
You can send scanned documents to an FTP(S) destination on an HP MFP (Multifunction Printer) device by creating an Embedded Directive or creating a button on the MFP.
Creating an Embedded Directive for use with FTP(S)
To create an Embedded Directive
Open the Web Client and select Distributions > New.
In the New Message dialog, select Network Folder as the Type.
In the Select destination drop-down select the FTP folder.
Complete all needed fields to send a message, and then send the message to the server.
Go to the HP MFP.
Select Public Distributions (or Personal Distributions).
Select the newly created Embedded Directive that will be using FTP.
Scan a document.
Creating a new button on the device using FTP(S) to a network folder
To create a new button
From the Web client, create an Embedded Directive that:
Is public (published). In this way when it is used, the job will be from the scanning user rather than the Embedded Directive owner.
Routes to the Network folder using FTP.
Right-click on the device group and select Properties.
Click on the Buttons tab and select Add.
In the Add Button dialog, select Scan to Distribution in the Type drop-down.
In the Device Home Screen tree view, select the new button that was just created and click the Properties button.
When the Button Properties dialog opens, click the Options tab.
Search for and locate the Embedded Directive that will send via FTP to a network folder. Highlight the Embedded Directive and click Select.
Click OK to complete the setup.
A new button will be available on the device that will use FTP to scan to a network folder.
