About Composer Priority
The Composer component can be configured to have a priority for composing messages. The default priority is Normal. You can set the composer to have a Low or a Very low priority if needed. For example, OCR jobs are resource intensive and absorb 100% of CPU starving other processes on the machine. You can therefore, set the composer designated to process OCR jobs to a low priority. This will allow all other jobs to proceed ahead of the OCR job and reduce queue congestion.
Configuring Composer priority
You can configure Composer priority by using the Server Administrator > Components node.
To configure Composer priority
  2. Double-click the Compose component to open the Properties dialog box.
  3. Click Composers to open the Composers page listing the composers in your environment opens.
  4. Select the composer you want to configure and click Properties. The Composer Package Properties dialog box appears.
  5. In the Conversion Priority drop-down list, select one of the priority levels.
    • Low
    • Very low
Note: The default priority level is Normal.
  1. Click OK to save your changes.
About Compose component
