About InterFAX Connector
The InterFAX connector allows the server to send and receive faxes via the cloud-based InterFAX fax service.
Configuring the InterFAX connector
To configure the InterFAX connector
  2. Navigate to Connectors > Select New Upland AccuRoute Connector > InterFAX
  3. Enter the appropriate Server Address and click Next.
  4. Specify a name for the connector and click Next.
  5. Enter a valid username and password obtained from the InterFAX and click Next.
  6. Click Finish. The InterFAX connector is added to the server.
Note: To add multiple InterFAX Connectors, additional licensed are required.
Routing an outbound fax message
To route an Outbound fax message using InterFAX connector
  1. Launch  Message server Administrator > Default groups > enable the Fax message option.
  2. In the Messages node, select New > Test Message. The Test Message window appears
  3. Specify the Sender Email, Recipients (outbound fax number), Subject, Comments, and Attachments.
  4. Click Deliver. The Fax message is routed using a specific routing rule created for the InterFAX and delivered to the specified recipients.
Note: No configuration is required in Message Server Administrator to receive Inbound Fax message.
