Configuring Group Network Printers
                                            The
Install the printer driver on the server using the standard Windows installation procedure.
Launch Server Administrator, expand the tree view, and click Configuration > Groups.
In the right pane, double-click on the Default group (or applicable group). The Group page is displayed.
Click on the Printers tab.
Select Enable members of this group to select the specified Printers.
Click the Add button. The Add Printer page is displayed.
Enter the printer information. For example:
Click OK. Click OK again to save the changes. Refer also to Selecting a network printer.
Modifying Network Printer Properties
You can modify the Network Printer properties by using the Server Administrator > Configuration node.
To modify the Network Printer properties
Launch the Server Administrator, expand the tree view, and click Configuration > Groups.
Highlight the printer that needs to be modified and click Properties.
On the Edit Printer page make all needed changes and, when finished, click OK.
Click OK again to close the Group page.
Removing a Network Printer
You can remove a network printer by using the Server Administrator > Configuration node.
To remove a network printer
Highlight the printer that needs to be modified and click Remove.
Click OK to close the Group page.
