Mapping Prompt Values Guidelines
The Mapped Property page can map a prompt value to a message recipient property in four different ways.
  • The value entered in Property is an actual message recipient property (examples are prEmail, prDestination, prName).
  • The value entered in Property is a template variable used to display on a coverpage (examples are SENDER_EMAIL, RECIPIENT_DESTINATION).
  • The value entered in Property is an actual DMS property and the DMS property check box is checked (examples are prDMSDocDescription, prDMSDocName ).
  • The value entered in Property is a DMS custom field and the DMS property check box is not checked (examples are DOC_NAME, AUTHOR, CUSTOM1).
Example of Configuring Prompts
The following example illustrates how to configure the DMS Document Name Prompt.
  1. Open the Embedded Directive Prompts page.
  2. Click New. The Prompt Properties page opens.
  3. In the Type text box, leave the type as Text.
  4. In the Label text box enter the label for the prompt; for example, Document Name.
  5. In the Instructions text box, enter "Enter document name".
  6. Click Next. The Prompt Properties Mapping page opens.
  7. Click New. The Mapped Property page opens.
  8. In the Property drop-down, enter prDMSDocDescription and then check the box next to DMS.
  9. Click OK.
  10. Select New again.
  11. In the mapped Property page, enter prDMSDocName and then check the box next to DMS.
  12. Click Next then Finish, then OK to save your changes.
Configuring Embedded Directive Prompts
Guidelines for Mapping Property Values for Prompts
