Modifying Server Properties
You can modify server properties by using the Server Administrator > Properties dialog box.
To modify server properties
  2. On the Server Administrator tree, right-click the server name. The Properties shortcut menu appears.
  3. Select Properties. The Server Properties dialog box appears.
  4. Select any of the following tabs.
    • Settings
    • Address Book
    • Cluster
  5. Specify the appropriate parameters as needed.
  6. Click OK.
About Server Properties
