Lotus Notes Integration
                                            The following configuration is available for server installations integrated with Lotus Notes.
Configuring lookup methods
Integration with Lotus Notes is supported by message delivery to and from the Lotus Notes clients by way of the SMTP connector. Inbound message delivery is accomplished by configuring the lookup for the SMTP connector to the Domino server.
The server utilizes its connection to the Notes server to accomplish the following tasks.
- Authenticate users
 - Retrieve sender and recipient information for cover pages and routing sheets
 - Identify the recipient of inbound messages based on the recipient’s DID extension or fax number
 - Display the contents of the global directory when queried from the Server Administrator
By default, the Server Configuration wizard adds a search base for DID/DTMF lookup configuration.
