You can validate a message property after creating it by using the Validation tab on the Property Dictionary Item page.
To validate a message property
                                                    Create a new message property. For instructions, see Creating a message property.
                                                    On the Property Dictionary Item page, click theValidation tab.
                                                    Click Validate and then select the Use Server Validation option.
                                                    From the drop-down menu, select the message property for which you are setting the server validation.
                                                    Click OK to save your changes to the message property.
