Creating a DMS Document Profile
Document Profiling also known as Document Tagging is a feature that helps users access and retrieve documents stored in a document management system (DMS). A document profile specifies the DMS location, format, and metadata for delivery, identification, and searching purposes. You can create DMS profile records when creating distributions and using My Files.
Before you begin
The Desktop Client must be installed on your desktop. You must configure the DMS by using the Desktop Client before creating distributions and using My Files.
Configuring the DMS
You can configure the DMS by using the Desktop Client > Tools > Configure DMS option.
To configure the DMS
  1. Start the Desktop Client.
  2. Select Tools > Configure DMS and the appropriate DMS from the shortcut menu.
  3. Specify the DMS Configuration parameters.
  4. Click Next.
  5. Click Finish.
Note: Contact your Administrator for DMS configuration details, if necessary.
See the Desktop Client > Tools > Configure DMS menu and DMS Configuration dialog box examples below.
Expand to view more.
