About Desktop Client Connector
The Desktop Client connector, when installed on an Upland AccuRoute server, allows communication with existing Fax Sr. Client v5.4 installations. You can have up to four instances of this connector.
Note: Do not modify this setting unless an Upland AccuRouteTechnical Support Representative instructs you to do so.
To access the Desktop Client connector
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Double-click the Desktop Client connector to view its properties.
Desktop Client connector requirements
You must have the following installed and configured before you can install a Desktop Client connector.
  • Upland AccuRoute server with all required configurations
  • Workstations with Windows XP operating system
Adding a Desktop Client Connector
Configuring the Desktop Client Connector
Creating Inbound and Outbound Faxing Rules
