About Prompts
You can enable members of a group to use specific prompts that you do not want available to all users. Once a user in the group logs in to a device, they receive the prompts configured for the group.
In the Server Administrator, select Groups.
Right- click the appropriate user groups.
Select Properties on the shortcut menu. The Group Properties dialog box appears.
In the General left pane, expand Features if necessary.
Select Prompts. The Prompts list appears.
Select Enable members of this group to prompt for the following properties check box.
Select the appropriate prompts.
Select OK.
