About Server Monitor Tests
The Server Monitor default tests are created when you add a server. All tests reside in the details pane. You can also add new tests at any time. Tests define which events to monitor and what actions to take when specific test criteria are met.
You can:
  • Modify - Modifies an existing test
  • Remove - Removes an existing test
  • Add - Adds a new test
The first screen of the test configuration wizard is different for each new test. The additional screens are the same for each test.
Understanding test criteria descriptions
The name that displays is the name you assigned to the test on the last screen of the Create New Test Criteria wizard. It is a good idea to make the test name as descriptive of the test as possible.
Note: The test name is set by default on the last screen of the Create New Test Criteria wizard. You can change this name at any time.
Working with default tests
When you add a server to the Server Monitor Administrator, a set of default tests are created. Right-click a test (or, click Action on the toolbar) to access the available options:
  • Properties - Opens the Create New Test Criteria wizard
  • Delete - Deletes the selected test
Default tests created when you add a server to the Server Monitor
Test Type
Test Criteria and Actions
Composers If compose verification fails, send an email.
Connector Manager If the number of messages in the queue is greater than 100, send an email. Note: This test is applied for all configured connectors.
Connectors If any of the connectors are disabled, send an email.
Database Size If the MSDE database size is greater than 1.5 GB and less than 1.8 GB, send an email once every 24 hours. If the MSDE database size reaches 1.8 GB, stop the service. Note: These tests are generated only if MSDE is the installed SQL database.
Filescan Folder If the percentage of free disk space is less than 20%, send an email. If the age of control files is greater than 60 minutes, send an email. Note: These tests are generated only if the Filescan connector is installed.
Server Disk Space If the percentage of free disk space is less than 20%, send an email once every 24 hours. If the percentage of free disk space is less than 5%, stop all services.
Services If any of the services are not running, send an email.
Telco Folder If the percentage of free disk space is less than 20%, send an email. This test is applied for both the Recv and Send folders.
Telco Modem Services If the percentage of free disk space is less than 20%, send an email. If the oldest item in the queue (for the RecvLocal folder) is more than 60 minutes old, send an email.
Workflow Components If the oldest item in the queue is more than 60 minutes old, send an email. This test is applied to all components.
Configuring Test Screens
Actions and Test Wizard
Optional Server Monitor Configuration
