About WebApps BCC and Confirmation Options
Administrators can show or hide the Email copy as BCC (Blind Carbon Copy) recipient to option by using the Create Distribution > Options tab. WebApps users will not see or be able to select a BCC recipient when creating distributions. The default is to show the BCC option. The option must be cleared in the Server Administrator in order to hide it.
Hiding the BCC option
To hide the Email copy as BCC recipient to option
  2. Expand Configuration on the Server Administrator tree.
  3. Select WebApps. The profiles appear in the WebApps Details pane
  4. Select the appropriate profile; for example, Default. The Profile Properties dialog box appears.
  5. Select the Applications tab.
  6. Select Create Distributions. The Create Distribution Application Properties dialog box appears.
  7. Clear the Email copy as BCC recipient to check box.
  8. Click OK or continue with Confirmations.
See the Create Distribution Application Properties dialog box example below.
Managing confirmations
