Activating the Server License
After installation, the server uses a 60-day demonstration license. At some point during this time, you should activate the server license. This can be accomplished:
  • Automatically when you enter an activation code and the server is on a system that has access to the internet.
  • Manually if the server does not have access to the internet. In this case, you will:
    • Submit and validate the activation code.
    • Create an Export file into which the activation code is copied.
    • Create an Import file and use this file for activation from a system that does have internet access.
