Installing ObjectArchive
ObjectArchive provides data storage and retrieval. The data can be scanned images, multimedia, and other textual/non-textual data. The data is stored as individual objects with unique object keys. The object keys are 128-bit (16 bytes) Universally Unique IDs (UUIDs) and are the primary methods of accessing (storing/retrieving) data from the archive database.
Note: Important! ObjectArchive must be installed on a system remote from the server.
When scaling an environment with additional connectors or components, always consult Technical Support. For information, contact your Account Manager. Technical Support can assist you in correctly identifying potential bottlenecks in the system based on workload and other factors. Moreover, Technical Support can provide helpful information on the overall impact of increasing the speed and efficiency of the system. Performance and stability consulting are available for a fee.
If a detailed analysis of the environment is necessary, Technical Support may recommend a fee-based consultation.
Note: Important! ObjectArchive is not cluster aware.
Configuring ObjectArchive
