Upgrade Preparation
Server version verification
You can upgrade to the Upland AccuRoute Server v6.6 from the following versions.
Upland AccuRoute Server v5.0 through v6.5
Note: If you are running AccuRoute v4.x, first upgrade to v5.0 and then follow the instructions in this guide to upgrade to v6.6.
To check the version of your server
  2. On the Server Administrator tree, right-click the server name.
  3. Select Properties from the drop-down menu. The version is listed in the General tab of the Properties page.
  4. Verify that the version of the server is listed above.
Server preparation
Applying the Upgrade
