About Bursting Connector
The Bursting connector allows users the opportunity to break up (burst apart) document batches. It uses bar codes to identify and split up customer documents with the ability to send documents to multiple locations. No routing sheets are required to use the Bursting connector. In addition, the Bursting connector uses RuleSets to direct document delivery and can only be used with PDF files.
Note: The Bursting connector requires the Data Extractor license.
To access the Connectors node
On the console, expand the Server Administrator tree.
Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
- Right-click Connectors on the console. The Connectors shortcut menu appears.
- Select New Upland AccuRoute connector > Bursting. The Create New Connector wizard appears.
- Select and specify a server address, if necessary.
- Click Next.
- Name the Bursting connector in the Name box or keep the default name.
- Click Next.
- Select Email from the Route To: drop-down list and click Next.
- Click Finish. The Bursting connector is created and appears in the Connectors details pane.
- Right-click the new Bursting connector in the Connectors details pane and select Properties. The Connector Properties dialog box appears.
- Select Configuration tab > Any barcode and click the Properties button. The Barcode Properties dialog box appears.
- On the General > Regular Expression to match box, type .* if necessary, and click Test. The Regular Expression Test dialog box appears.
- Click OK.
- Select the Batch Layout tab.
- Select Any barcode and click Add. The Barcode Properties > Payload Pages dialog box appears.
- Type a name in the Name box for the Payload Pages settings (optional).
- Select one of the following settings.
- 0 or more pages (default)
- 1 or more pages
- Exact number of pages
- Min
- Max
- Range of pages
- Ensure the Retain pages in resulting job check box is selected.
- Click OK.
- Select the Job Properties tab and click Add to add any job properties you want to use.
- Click OK on the Set Job Properties dialog box.
- Click OK on the Barcode Properties dialog box. The Bursting connector is ready for use.
You can configure the Bursting connector to break up document batches only when the barcode value changes.
To configure the Bursting connector
- Select the Bursting connector in the Connectors details pane. The Bursting connector Properties dialog box appears.
- Select the Configuration tab.
- Select Any barcode .* in the Name and Regular Expression table. The Barcode Properties dialog box appears.
See the Barcode Properties dialog box example below.
- Select the Burst only when Barcode Value changes check box.
- Click OK.
