About Separator Page Templates
You can locate the separator page templates on the Upland AccuRoute server at [ServerInstallFolder]\Samples\EmbeddedDirectiveManager.
To work with separator page templates, you need to select an editor application. Save the separator page templates as PDF, TIFF, or RTF files.
After you edit the separator page template, save it in the following directory on the server.
[ServerInstallFolder]\Languages\ENU\Templates\
Note: Important! The file name of the cover page template should not contain any spaces.
Types of separator page templates
You can use the following templates to create two types of separator pages.
  • Attachment separator pages
  • Job separator pages
When you use an Attachment separator page with a routing sheet, the system uses it to separate individual documents from each other wherever the AttachmentSeparatorPage(s) are inserted.
You must associate the following variable with the job.
#ACCUROUTE_BATCH TRUE
Job separator pages
When you use a Job separator page with a routing sheet, the system uses it to separate delivered documents into individual jobs wherever the JobSeparatorPage(s) are inserted.
You must associate the following variables with the job.
#prEnableJobSeparatorProcessing 1
About Notification Message Templates
About Cover Page Templates
About Routing Sheets
