Configuring T.37 Fax Connector
You can configure the T.37 Fax connector by using the Server Administrator > Connectors node.
To configure the T.37 Fax connector
- Start the Server Administrator.
- Expand the Server Administrator tree.
- Click Connectors to list all connectors.
- Double-click T.37 Fax connector to open the Properties dialog box.
- Click the Options tab.
- In the Fax domain name box, verify that the domain name is correct. The format for the domain should be "@faxdomain.com" or "user@faxdomain.com".
- In the Email Filter box, verify you have the correct email filter. The default filter is %prDestinationLocalized%. The format of the filter must match the format that is acceptable at the destination. For example, when sending jobs to a fax domain, the @ sign should be removed. For more information on acceptable formats you can use, check with your service provider.
The following table lists the other variables you can use.
Variable |
Definition |
Example |
| %prDestinationLocalized% (mandatory) |
Destination fax number; for example, 978 555 1212. Note: Check with your service provider about the validity of the format of the destination fax number. |
%prDestinationLocalized% |
| %recip_name% (optional) | Name of the fax recipient | /TO=%recip_name% |
| %sender_name% (optional) | Name of the fax sender | /FR=%sender_name% |
| %prBillingCode% (optional) | Billing information for the server or the service provider. | /AC=%prBillingCode% |
- In the Subject box, type a descriptive subject for your message. See also, Configuring subject and comments of a fax message.
- In the Message body, type a brief message. See also, Configuring subject and comments of a fax message.
- Click Advanced to show the Advanced options.
- Select from the other options in the Options to be performed on E-mail address after substitution and the Remove the following characters sections.
Note: In the Options to be performed on E-mail address after substitution section, the Encapsulate in Quotes option is selected by default.
- Click OK to save your changes.
Limitations
When sending a fax using the T.37 connector, understand that some symbols can interfere with the routing of emails in general. Therefore, avoid the following symbols.
Symbol |
Description |
| To: | The "To:" line (as part of the @Mail.com address) |
| @ | Ampersand ("at" symbol) |
| ~ | Tilde |
| % | Percent |
| ( | Left parenthesis |
| ) | Right parenthesis |
| ; | Semicolon |
| > | Greater than |
| < | Less than |
| ^ | Carat |
| [ | Left bracket |
| ] | Right bracket |
| ! | Exclamation point |
| \ | Black slash |
| / | Forward slash |
| . | Period |
Creating a T.37 Fax Connector Outbound Routing Rule
Configuring a Fax Message Subject and Comments
