Modifying Server Profile
You can modify the Server profile by using the Properties page. When you complete this procedure, the server will begin processing messages by the new settings. These settings are overridden by the settings associated with a connector profile or user profile.
To modify the Server profile
On the Server Administrator tree, right-click the server name.
Click Properties from the drop-down menu. The Properties page opens.
Click Settings.
In the Manage Server Profile section, click Configure. The Server Profile Properties page opens.
Click Access Code option to add or remove access codes from the profile.
Click Billing Code option to modify the default billing code for the profile.
Click OK to save your changes.
You can modify the following Access code options by using the Server Profile Properties page.
To modify access codes
Open the Server Profile Properties page.
Click Access Codes.
Modify the following options as needed.
Option |
Description |
Override server's profile settings |
Select this option if you want the cover pages you add to the profile to override the cover pages in the Server Profile. Note: If you are modifying the Server GeniProfile, you do not see this option. |
Add |
To add a new access code
Delete |
To delete an access code
Set Default / Clear Default |
To designate an access code as the default access code
When you specify a default access code, the Set Default button changes to Clear Default. To remove a default access code
User must specify an access code to send message |
Select the check box beside this option if you require that all users of this server profile must choose an access code for all faxes they send. If you select this option and the users do not select an access code, the fax will fail. |
Merge list with default |
This option is no longer supported. |
You can modify the default billing code options by using the Server Profile Properties page. The default billing code is used to send a one-off fax message.
To modify the Billing codes
Click Billing Codes.
Modify the following optiions as needed.
Option |
Description |
Select this option if you want the cover pages you add to this Profile to override the cover pages in the Server Profile. Note: If you are modifying the Server GeniProfile, you do not see this option. |
Add |
To add a new billing code:
Delete |
To delete a Billing code:
To designate a billing code as the default billing code:
When you specify a default billing code, the Set Default button changes to Clear Default. To remove a default billing code:
User must specify an billing code to send message |
Select the check box beside this option if you require that all users of this server profile must choose a billing code for all faxes they send. If you select this option and the users do not select a billing code, the message will fail. |
Adding Dialing Rules Access and Billing Codes
Using Dialing Rules Access and Billing Codes
