Optional Server Monitor Configuration
Use the following optional procedures to configure the Server Monitor.
If you have a Remote Administrator MMC, you can add Server Monitor to the MMC console.
- Open the Server Administrator.
- Select Console and select Add/Remove Snap-in.
- Click Add to view a list of available snap-ins.
- Scroll down the list of available snap-ins, select Server Monitor Administrator, and click Add. The Specify Server Monitor window appears and prompts you for a network address.
- Enter the Network IP Address or name of the server you want to monitor.
- Click Finish, Close, and then OK.
The Suspend Monitor feature allows you to suspend monitoring of the server for specified dates and times.
- Right-click the server and select Properties. The Server Properties screen appears.
- (Or, highlight the server, click Action on the toolbar and select Properties.)
- Click the Suspend Monitor tab.
The available options are:
- Add - Allows you to enter new days and times to suspend monitoring.
- Remove - Allows you to delete single or multiple suspend monitoring specifications.
- Properties - Allows you to modify specifications for an existing Suspend Monitor item. You can modify only one item at a time.
- Click Add on the Suspend Monitor tab. The Suspend Monitor Data screen appears.
- Select the Days of the Week and the Time Period for which you want to suspend monitoring.
- Click OK.
- Highlight an existing specification on the Suspend Monitor tab. You can select multiple specifications using Ctrl-Click and Shift-Click.
- Click Remove. The Are you sure you want to delete the selected item? message appears
- Click Yes to delete it or No to keep it.
- Click OK to close the Suspend Monitor tab.
- Highlight an existing specification on the Suspend Monitor tab and click Properties. The Suspend Monitor Data screen appears.
- Make any changes needed and click OK.
