Routing Sheet Variables Lists
The following table lists variables that are available for Routing Sheets. For a list of other variables that can be used in Routing Sheets, see List of template variables (in alphabetical order).
Variable |
Description |
%ROUTINGSHEET_TITLE% |
Title of the Routing Sheet created by the end user |
%OMEDID_BARCODE% |
The barcode image is replaced with this variable |
%SENDER_EMAIL% |
Sender's email address |
%ROUTINGSHEET_DATE_CREATED% |
Date the Routing Sheet was created |
%ROUTINGSHEET_DATE_EXPIRES% |
Date the routing will expire (if applicable) |
%ROUTINGSHEET_SINGLE_USE% |
Indicates the Routing Sheet is single use |
%EMAIL_DESTINATION.1% |
First email recipient’s email address (The number indicates how many email recipients to list.) |
%EMAIL_DOCTYPE.1% |
Final form to be sent to the first document management location |
%PRINT_DESTINATION.1% |
First printer recipient |
%FAX_DESTINATION.1% |
First fax recipient |
%UNC_DISPLAY_DESTINATION.1% |
First network folder recipients |
Creating Routing Sheet Templates Guidelines
