About Silent Server Install
A Silent Server Install is the installation of a software program that requires minimal or no user interaction. It is a convenient way to streamline the installation process of an application. Administrators can do a silent server install on Upland AccuRoute servers that are part of an organization’s network.
In addition, it can be applied to any server configuration; for example, Server Cluster Primary or Secondary, Disaster Recovery, and/or Remote Component servers.
Before you begin
The silent server installation process requires a Server Prerequisite Install Check and a recording of the server installation process on a server where a server installation does not currently exist. After recording the server installation, a playback of the recorded steps is then executed on as many different servers as needed. The setup.iss and settings.json files are created during the process. Post installation and configuration tasks are required for licensing, rulesets, connectors, and any other components specific to your workflow environment.
