About DMS Connector
The DMS connector routes documents from the server to your company document management system (DMS). The inbound document must include a Routing Sheet. You can generate a Routing Sheet using the Upland AccuRoute Desktop or Web Client. For more information on the Upland AccuRoute Desktop Client, see the AccuRoute Desktop Client User Guide.
When a Desktop or Web Client user selects a DMS as the destination for a document and generates a Routing Sheet, the DMS connector creates a document ID and a pending document in the DMS. When the actual document arrives at the destination DMS server, the DMS connector locates the placeholder and replaces it with the actual document. If there are multiple documents arriving on the server, the DMS connector creates a new document ID for each subsequent document.
Note: If a user creates a Routing Sheet for multiple use, care must be taken to not delete document IDs in the DMS. The DMS connector must be able to locate the original document ID each time it routes a document with the same Routing Sheet.
You can configure a DMS connector for only one DMS. If your company uses multiple document management systems, you must configure a DMS connector for each one. To purchase additional DMS connector licenses, contact your Account Manager.
You can have up to four instances of this connector.
Note: Do not modify this setting unless a Technical Support Engineer instructs you to do so.
Access DMS connectors
To access DMS connectors
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Double-click the DMS connector to view its properties.
DMS connector requirements
The requirements for the DMS connector are:
Note: If you are planning to use a remote DMS connector, the DMS client application must be installed and configured on the remote system.
  • Upland AccuRouteDesktop or Web Client configured for your DMS.
Note: The DMS connector is associated with Upland AccuRoute Client applications and DMS Library Kit. The DMS libraries allow the server to communicate with your DMS. For more information, see DMS libraries.
Supported Document Management Systems
DMS Libraries
Adding a DMS Connector
Configuring DMS Connector Billing Lookup and Validation
Macro Security Issue
