About Fax Sr. Connector
The Fax Sr. connector allows theUpland AccuRoute server to communicate with the Fax Sr. server. When you add and configure the Fax Sr. connector, the server can deliver faxes that originated on the Fax Sr. server. Conversely, the Fax Sr. server can deliver faxes that originated on the server.
To access a Fax Sr. connector
Expand the Server Administrator tree.
Select Connectors. The details pane lists the connectors that are licensed with your server.
Double-click the Fax Sr. connector to view its properties.
Fax Sr. connector requirements
Before you can install the Fax Sr. connector, you must:
Install a fax board on the servers that will deliver and receive faxes.
Install and configure the Fax Sr. server and the AccuRoute Server on two different systems within your company's WAN.
Create appropriate LCR rules for the Fax Sr. server.
Create appropriate routing rules for the AccuRoute Server. (These rules determine which faxes will move from one server to the other via the Fax Sr. connector on the AccuRoute Server.)
Routing faxes from the Fax Sr. server to the AccuRoute Server
If you want the AccuRoute Server to deliver faxes that originated from the Fax Sr. server, you need to:
Remove the fax boards from the Fax Sr. server and add them to the AccuRoute Server
Note: The fax boards you use with the Fax Sr. server may not be compatible with the AccuRoute Server. For information on supported fax boards, consult the Server Installation and Integration Guide.
Create or modify LCR rules on the Fax Sr. server so that it routes the appropriate faxes to the AccuRoute Server
You must also add the Fax Sr. connector to the AccuRoute Server.
Routing faxes from the AccuRoute Server to the Fax Sr. server
If you want the Fax Sr. server to deliver faxes that originated from the AccuRoute Server, you need to:
Remove fax boards from the AccuRoute Server and add them to the Fax Sr. server.
Create routing rules that specify which messages should be routed to the Fax Sr. Server.
You must add the Fax Sr. connector to the AccuRoute Server.
If your Fax Sr. Server uses Dialogic fax boards (which are not supported by the AccuRoute Server) you need to configure the Fax Sr. server to route faxes originating from the AccuRoute Server.
This is what you need to do:
Add the Fax Sr. connector.
Create one or more outbound rules that route faxes from the AccuRoute Server to the Fax Sr. server.
About Fax Sr. Connector Workflow
Creating Fax Sr. Server LCR Rules
