About Fax Sr. Filescan Connector
The Fax Sr. Filescan connector allows the AccuRoute Server to process Fax Sr. Filescan files. For complete instructions on installing, configuring, and using the Fax Sr. Filescan connector, see the Fax. Sr. Filescan Connector Installation and Configuration Guide.
To access Fax Sr. Connectors
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Double-click the Fax Sr. Filescan connector to view its properties.
Fax Sr. Filescan connector requirements
Before you can install the Fax Sr. Filescan connector, you must:
  • Install AccuRoute Fax server v3.3.1 SR2 or later or AccuRoute Server 2.0.1 or later with Telco connector.
  • Install any version of Fax Sr. server.
Adding a Fax Sr. Filescan Connector
You can add a Fax Sr. Filescan connector by using the Server Administrator > Connectors node.
To add a Fax Sr. Filescan connector
  3. Right-click Connectors. Select New AccuRoute Server connector > Fax Sr. Filescan Connector. The Server Address page opens.
  4. Click Next. Alternately, if you want the connector to run on a remote server, click Remote Server and enter the server name. Click Next. The isplay Name page opens.
  5. In the Name text box, enter an appropriate name.
  6. Click Next. The Fax Sr. Filescan page opens.
  7. In the Specify the initial folder for Fax Sr. Filescan Connector to process section, enter the following information:
    • In the Select scan style text box, choose a style of operation from the drop down list.
    • In the Select scan folder text box, enter the local path to the folder (for example C:\faxsrfilescan\scan1). You can also browse to the folder and select it.
  8. Click Next.
  9. In the Default originator (if not specified in the scanned file) text box, enter the email of the default originator. By default this is Admin.
    The AccuRoute Server associates an originator email address with all outbound faxes. If this information is missing, the server associates the default originator email.
  10. Click Next. The Congratulations page opens.
  11. Click Finish. The Fax Sr. Filescan connector is listed in the Connectors details pane.
