About Filescan Connector
The Filescan connector works in conjunction with your company's Upland AccuRoute Server, providing users in your company with a method of submitting outbound documents to the server and providing your company with a method of routing inbound documents to a folder in the local area network.
Outbound documents
Your company can send documents using the Filescan connector. Outbound documents can be copied to a Filescan folder by individual users or network scanning devices.
filescan connector outbound documents diagram
By routinely monitoring Filescan folders in the local area network, the Filescan connector instantly detects documents and collects them. As soon as the Filescan connector collects a document from a Filescan folder, the connector interprets the control file—a simple text document that contains delivery instructions for the document—and makes this information available to the server.
Inbound documents
Your company can route inbound documents to a folder in the local area network. Using routing rules to configure this feature, you can choose any criteria for documents routed to a Filescan folder.
To access Filescan Connectors
  3. Select Connectors. The Connectors details pane lists the connectors that are licensed with your server.
  4. Double-click the Filescan connector to view its properties.
Filescan connector benefits
The Filescan connector provides the following benefits for numerous applications.
  • Support for network scanning devices - When used in conjunction with AccuRoute, the Filescan connector provides your company with a method of getting hard-copy documents from a network scanning device to your company's AccuRoute Server.
  • Automatic document routing - When used in conjunction with AccuRoute, the Filescan connector provides automatic document routing, an ideal solution for users who send documents to the same destination repeatedly.
  • Inbound document routing - The server can route inbound documents to a folder via the Filescan connector. AccuRoute supports this functionality.
  • Broadcast faxing - When used in conjunction with Genifax, the Filescan connector allows your company to send broadcast faxes simply by putting a document into a Filescan directory.
Adding a Filescan Connector
Sending Documents Using the Filescan Connector
