About Large Job Composer
Large job composers are configured primarily for scanning large documents that can be resource intensive. The advantage of configuring a large job composer is that it allows time consuming scan jobs to be handled by specific composers thereby freeing up other smaller or more important jobs to continue through the system without being blocked for a long time by the large jobs.
A scan job is handled by the large job composer only if:
  • It meets a specific document file size criteria
  • It meets a certain page count size (for PDF and TIF only)
  • The scan job was marked for a large job composer (by setting prUseLargeJobComposer to 1 on the job or in the rule that routes the job).
Note: A scan jobs that time out the first time is marked for a large job composer automatically for the retry.
If you request a large job composer for a job and a large job composer does not exist in your environment, the message does not queue up on a normal composer and fails.
Configuring a Large Job Composer
You can configure a large job composer by using the Server Administrator > Components node.
To configure a large job composer
  2. Double-click the Compose component in the Components details page. The Properties dialog box appears.
  3. Click Composers. All Composers in your server environment are listed. (By default, two composers are installed on the server. One is for General compose functions and the other for OCR compose functions).
  4. Select the composer you want to designate as a large job composer.
  5. Click Properties. The Composer Package Properties dialog box appears.
  6. Select the Large jobs option.
  7. Specify the criteria for the job. A job is considered large if:
    • It meets a specific document file size criteria - To specify the size of a document that should be considered a large job, select the Documents that re [ ] KB or greater option and type the size, in KB in the box.
    • It meets a certain page count size (for PDF and TIF only) - To specify a page count, select the Documents that are [ ] or more pages (TIF or PDF only) option and type the number of pages in the box,
    • The scan job was marked for a large job composer  - To specify, select the Jobs that request a large job composer option.
      A scan job is marked for a large job composer by setting prUseLargeJobComposer to 1 on the job or in the rule that routes the job.
  8. Click OK to save your changes.
