About Received Faxes and Default RuleSets
The
- Inbound messages against the Received Faxes Rulesets
- Outbound messages against the Default RuleSets
For WebApps and Outlook Administrators
Note: For
Received Faxes RuleSets
The Received Faxes RuleSets specify the following parameters.
- The criteria identifying which rule to match.
- The actions to perform.
- Any failover actions, if needed.
Accessing Received Faxes RuleSets
To access the Received Faxes RuleSets
- In the Server Administrator, expand RuleSets.
- Select RuleSets > Received Faxes. The details pane lists the default Received Faxes rules created when you installed the server.
- Select a rule. The Rule Properties dialog box appears.
- Use the General tab to view and modify the properties, for example, priority order if necessary.
- Use the Criteria tab to view and modify the Criteria Expression if necessary.
- Use the Action tab to view, add, modify, duplicate, move, and remove other actions if necessary.
- Select OK.
Default RuleSets
The Default RuleSets specify the following parameters.
Accessing Default RuleSets
To access the Default RuleSets
- Select RuleSets > Default. The details pane lists the Default rules created when you installed the server.
- Select OK.
Note: You can also create custom User RuleSets or modify or delete existing rules, as needed. For information on how to create a new custom rule, see User RuleSets.
