About the Server License Key
After installation, the server uses a 60-day demonstration license. At some point during this time, the server license must be activated. This can be done automatically or manually based on whether the server has access to the internet.
Before the 60-day demonstration license expires
You must provide a license key. To obtain a license key, contact your Account Manager. You can view or activate other license keys at any time, if necessary.
Special features
In addition, certain Server Administrator features like components and connectors require licensing. Administrative options for specific features are available only if your company purchased a license.
Viewing the server license key
You can view the server license key by using the Server Administrator > Licensing dialog box.
To view the server license key
On the Server Administrator tree, right-click the server name.
Select Licensing. The Licensing dialog box appears. It lists your active license keys and the features associated with each key.
Note: If you want to review a licensed feature's properties, select the feature, and click Properties.
Changing the license key
You can change a license key by using the Server Administrator > Licensing dialog box.
- Start the Server Administrator.
- In the Server Administrator tree, right-click the server name.
- Click Licensing . The Licensing dialog box appears.
- Select the license key.
- Click Change. The Change License dialog box appears.
- Enter the new license number.
- Click OK to go back to the Server License page.
- Click OK to close the Server License page.
