About Server Monitor
The Server Monitor is a stand-alone application that monitors various components of an AccuRouteServer. It executes custom-created tests to detect workflow bottlenecks and system failures. Conditions that can be monitored include the size of the message database, available disk space on the server, the size of Send and Receive folders, the status of services and connectors.
Tests are the core of the server monitor and can be configured to define which server events to monitor and what actions to take. Use the following procedures to install, launch, view, connect, and add servers to the Server Monitor service.
Note: Administrators can install the Server Monitor on the AccuRoute server instead of using a separate server. This allows Administrators with single server configurations to run Server Monitor / Help Desk Dashboard without an additional server. However, this type of installation is associated with potential risks. For example, the Server Monitor will not be able to detect or send notifications if the main server goes down.
About Server Monitor Tests
Configuring Test Screens
Actions and Test Wizard
Optional Server Monitor Configuration
