About Universal Input Connector
The Universal Input connector picks up and processes XML documents and submits them to the Upland AccuRoute server for delivery to the intended recipients.
The Upland AccuRoute server installation includes the Universal Input connector. This connector specifically handles jobs from the Embedded Upland AccuRoute for HP OXPd client application. (It has a Translation.xsl tool it uses to process files scanned and delivered from HP devices.)
If appropriate for your environment, you can have additional Universal Input connectors.
Universal Input connector requirements
The Universal Input connector requires shared folders with correct permissions for the connector to monitor.
Use the following guidelines when creating folders for the Universal Input connector to scan.
  • Locate the folders on the Upland AccuRoute server or any other computer in the local area network.
  • All folders must be shared, with the Server user account having full control. User accounts for individual users and devices must have write permissions.
  • Create one folder if you want invalid XML files to remain in the folder until someone deletes them. Create two folders if you want the Universal Input connector to move invalid XML files to a different folder.
Accessing the Universal Input connector
To access the Universal Input connector
  3. Select Connectors. The details pane lists the connectors that are licensed with your server.
  4. Double-click the Universal Input connector to view its Properties.
Adding a Universal Input Connector
Enabling Universal Input Translation
