Adding the Notes Connector
Before adding the Notes connector, you must manually register the connector executable and then add the Notes connector.
Manually registering the Notes executable
To manually register the Notes executable
Log in to the system running AccuRoute Server using an account that belongs to the Administrator.
Open a command prompt.
- Enter the following command.
"C:\Program Files\Omtool\Omtool Server\bin\OmConGFNotesU.exe" -regserver
where C: is the drive where the AccuRoute Server is installed.
Press Enter.
Adding the Notes connector
To add the Notes connector
Start the AccuRoute Server Administrator:
Expand the Server Administrator tree, right-click Connectors >New AccuRoute Server connector for> Notes. The License page opens.
In the License text box, enter a valid license and click OK. The Server Address page opens.
Select Run on the Omtool Message Server option. Click Next. The Display Name page opens.
In the Name text box, enter a name for the connector and click Next. The Lotus Notes Connector Lookup Configuration page opens.
In the LDAP Host Name text box, enter the name of the system which has the LDAP server.
In the Search base text box, enter the lookup search base in the LDAP. Click Next.
Click Finish. The connector is added to the AccuRoute Server.
Modifying the Fax Mail Box Access Control List
Configuring Server Notes Installation Path
Running the Notes Setup Program
Configuring Notes Connector DID/DTMF Lookup
Notes Address Book Variables List
