Configuring Zonal OCR Connector
You can configure a Zonal OCR Connector after a Zonal Form Definitions User has completed and saved a Zonal Form Definitions project by using the Server Administrator Console and the Create New Zonal OCR Connector wizard. In addition, you must create and map job properties to a form project and create a Zonal OCR workflow.
To configure the Zonal OCR Connector
  2. Expand the Server Administrator tree and right-click Connectors.
  3. Select New Connector > Zonal OCR. The Create New Zonal OCR Connector wizard appears.
  4. On the Server Address wizard page, use the default Server address or select Remote Server and type the name of the computer where the connector is installed.
  1. Click Next.
  2. On the Display Name wizard page, use the default or type a ZOCR Connector name in the Name box.
  3. Click Next.
  4. On the Forms Project wizard page, select a form project on the Forms Project list.
See the Forms Project wizard page below.
Note: You may periodically have to change the form project that the Zonal OCR Connector is associated with. Although a single Zonal OCR Connector can have multiple projects only one form project can be associated with the connector at a time.
  1. Click Next.
  2. On the Route to wizard page, select a routing destination for the extracted data fields; for example, a database, document management system, or queue.
  3. Click Next.
  4. Click Finish.
Note: Ensure the Zonal OCR Connector on the server is enabled on the Connector list.
More Administrator Zonal OCR tasks
After configuring the Zonal OCR Connector, you must also complete the following Zonal OCR tasks.
  • Create and map job properties to a form project.
  • Create Zonal OCR workflow.
About Zonal Form Definitions and Data Extraction
Using Zonal Form Definitions Quick Start Guide
