Creating a Document Stamp
You can create a Document Stamp by using the Server Administrator > Configuration node.
To create a Document Stamp
  1. Start the Server Administrator and expand the Configuration node.
  2. Right-click Document Stamps and select New > Document Stamp. The Document Stamps Properties screen appears.
  3. In the General tab, enter a name for the Document Stamp in the Name text box.
  4. Define the set of specific characteristics for a Document Stamp on this screen. To begin, assign a location on the page for it from the Location drop-down menu.
  5. At the Rotate field, enter a degree of rotation, if you want the stamp to be anything but horizontal in orientation.
  6. If you want this Document Stamp to include text, select the Text radio button to enable the Text section.
  7. In the Text section, select the Mode you prefer (Outline, Solid, or Transparent) from the Mode drop-down menu.
  8. Select a Font and Font Size from those drop-down menus.
  9. If you'd like the Document Stamp to be a color other than the default black, click the Ellipsis .... button and select a color from the Color screen. Click OK.
  10. Enter the text for this Document Stamp in the Text box.
  11. Define the horizontal and vertical alignment of your Document Stamp from the Alignment drop-down menus.
  12. If you want this Document Stamp to include an image, select the Image radio button and enter a Filename path for the image of interest.
  13. Click OK. The new Document Stamp appears in the results node for Document Stamps.
About Document Stamps
Configuring Document Stamps for Groups
Configuring a Document Stamp Rule
