Lexmark Supported Devices
Upland AccuRoute v7.0
The Upland AccuRoute and Lexmark application, UplandESFApp.fls v1.3.1 has been developed to support large document management on FrameWork v6.0+ devices with or without a hard drive.
Lexmark printers supporting eSF versions 7 and their specifications
The following table lists the printer models that support eSF. When signing an application, it is certified only against the base model and all the derivatives that belong to the printer series are included automatically.
Note: Printers with displays that are smaller than 4.3 inches are not supported.
The following acronyms are used in the table below.
fw - framework
mfp - multifunction printer
NA - Not Applicable
sfp - single function printer
Base Model |
Derivative Model |
Family Category |
| CX83x | XC8355 |
androidxlargescreen mfp fw7 |
| CX963x | XC9655 |
CX961x CX962x |
XC9635 XC9645 |
| CX95x |
XC9525 XC9535 |
| CS96x | N/A |
androidsmallscreen sfp fw7 |
CS730de CS735de |
C4342 C4352 |
androidsmallscreen sfp fw5 fw6 fw7 |
| CX730de | XC4342 |
androidxlargescreen mfp fw5 fw6 fw7 |
| CX735adhe | XC4352 |
| CS94x | NA |
| CX94x | XC94xx |
| CX93x | XC93xx |
| MX931x | NA |
| MX43x | XM31xx |
androidsmallscreen mfp fw5 fw6 fw7 |
| MX53x | NA |
| MX63x | XM3350 |
androidwidescreen mfp fw5 fw6 fw7 |
| CX53x | NA |
| CX63x | NA |
| CS63x | NA |
| CS82x | C61xx |
androidsmallscreen sfp fw5 fw6 |
| CX820x | XC61xx |
androidwidescreen mfp fw5 fw6 |
CX825x CX86x |
XC81xx |
androidxlargescreen mfp fw5 fw6 |
| CS72x | C41xx |
| MS62x | M32xx |
| MX522x | XM12xx |
androidsmallscreen mfp fw5 fw6 |
| MX62x | XM32xx |
| CS92x | XS9xx |
| CX92x | XC92xx |
MS822de MS826de |
M52xx |
| MX72x | XM53xx |
| MX82x | XM73xx |
| CS62x | C22xx |
| CX52x | XC22xx |
| CX622x | N/A |
| CX625x | XC42xx |
Note: See firmware and framework versions below.
Firmware xx.07y.zzz is running framework version 6.3.
Firmware xx.05y.zzz is running framework version 6.2.
Firmware xx.04y.zzz is running framework version 6.1.
Firmware xx.03y.zzz is running framework version 6.0.
