Supported Devices
The following table lists devices supported by Upland AccuRoute Embedded Device Client organized by release version.
Note: The Supported Devices list is updated on a per release basis. The list is subject to changes made by the device manufacturer that may not be listed here. Contact or visit the device manufacturer website for the latest information if necessary.
The Upland AccuRoute MEAP (Multifunctional Embedded Application Platform) application was developed using the MEAP SDK version 5.10 and is backward compatible. See a list of supported Canon devices below.
| imageFORCE C7165 | 4.00 | ||
| Canon i-SENSYS X C1538iF II | 2.01L | ||
| Canon Color imageCLASS X MF1538C II | 2.01L | ||
| Canon imageCLASS X C1538iF II | 2.01L | ||
| Canon Satera MF842Cdw | 2.01L | ||
| Canon i-SENSYS MF842Cdw | 2.01L | ||
| Canon imageCLASS MF842Cx | 2.01L | ||
| Canon imageCLASS X C1533iF II | 2.01L | ||
| Canon i-SENSYS X C1533iF II | 2.01L | ||
No supported device list updates in this release. See Supported Devices for HP CR Release 2.3.0.
The following table lists the printer models that support eSF. When signing an application, it is certified only against the base model and all the derivatives that belong to the printer series are included automatically.
Note: Printers with displays that are smaller than 4.3 inches are not supported.
eSF .71.004
The following acronyms are used in the table below.
fw - framework
mfp - multifunction printer
NA - Not Applicable
Derivative Model |
Family Category |
| CX83x | XC8355 |
android xlarge screen mfp fw7 |
| CX963x | XC9655 |
| CX961x | XC9635 |
| CX962x | XC9645 |
| CX95x | XC9525 |
| CX95x | XC9535 |
| CS96x | NA |
android small screen sfp fw7 |
| CS730de | C4342 |
| CS735de | C4352 |
android small screen sfp fw5 fw6 fw7 |
| CX730de | XC4342 |
android xlarge screen mfp fw5 fw6 fw7 |
| CX735adhe | XC4352 |
| CS94x | NA |
| CX94x | XC94xx |
| CX93x | XC93xx |
| MX931x | NA |
| MX43x | XM31xx |
android small screen mfp fw5 fw6 fw7 |
| MS632dwe | M3350 |
| MX53x | NA |
| MX63x | XM3350 |
android wide screen mfp fw5 fw6 fw7 |
| CX53x | NA |
| CX63x | NA |
| CS63x | NA |
In this release, the EIP SDK version has been upgraded to 5.3 and is backward compatible. There are many different Xerox devices that support EIP. In some cases, the device may need to be at a minimum firmware level for EIP support. The recommendation is to always be at the latest version of the firmware.
See Xerox Product Support and Drivers for more information.
Note: When configuring Xerox devices, you must also enable HTTP or HTTPS in the Xerox device Embedded Web Server (EWS). Extensible Interface Platform (EIP) is the Xerox SDK which is used to develop AccuRoute server applications to work on Xerox devices. EIP services is used to register the buttons on a device. See the Embedded Device Client Installation Guide for more information.
Device |
EIP Version |
Minimum Firmware Version Required |
| Xerox® VersaLink® B625 Multifunction Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® VersaLink® C625 Multifunction Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® VersaLink® B415 Multifunction Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® VersaLink® C415 Multifunction Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® VersaLink® B620 Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® VersaLink® C620 Color Printer* | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® AltaLink® C8200 Color Multifunction Printer * | 5.3 | 122.xxx.xxx.xxxxx |
| Xerox® AltaLink® B8200 Multifunction Printer * | 5.3 | 122.xxx.xxx.xxxxx |
Note: * - Device available in VIC.
The Upland AccuRoute MEAP (Multifunctional Embedded Application Platform) application was developed using the MEAP SDK version 5.9 and is backward compatible. See a list of supported Canon devices below.
| imageRUNNER ADVANCE DX C359iF/C259iF | UFP ver: 3.15 | ||
| imageRUNNER ADVANCE DX 6980i | UFP ver: 3.15 | ||
| imageRUNNER ADVANCE DX 8905i/8995i/8986i | UFP ver: 3.15 | ||
| imageRUNNER ADVANCE DX C3935i/C3930i/C3926i/C3922i | UFP ver: 3.15 | ||
| imageRUNNER ADVANCE DX 4945i/4935i/4925i | UFP ver: 3.15 | ||
| imageRUNNER ADVANCE DX 719iF/iFZ/619iF/iFZ/529iF/iFZ | UFP ver: 3.15 | ||
Note: TLS 1.0/1.1 protocols have been disabled. In an effort to improve security and reliability, TLS 1.0 and 1.1 have been deprecated by the Internet Engineering Task Force (IETF). You are required to use or update this setting to a maximum and minimum version of TLS 1.2.
Supported Fonts by Platform
Supported fonts and font attributes vary by platform. See table below.
| Platform | Family Attribute | Size Attribute | Style Attribute | Letter-spacing Attribute |
| Oz | Ignored (one font family) | Ignored (one font size) |
Normal, bold |
Ignored |
| Oz with OXPd release 1.7 | Ignored (one font family) | Any (recommend > =12) | Normal, bold, italic | Any |
| Jedi - Windjammer | Monospace Courier, New Arial (default) | Any (recommend > =12) | Normal, bold, italic | Any |
| Jedi - Omni | HP Simplified | Any (recommend > =12) | Normal, bold, italic | Any |
Various devices have the following notations marked by an asterisk ( * ).
* Supports a subset of OXPd services.
** OXPd version 1.7 is required on Pro devices. Later versions of OXPd are not supported. OXPd Pro Services (OPS) is required to enable OXPd solutions on OfficeJet Pro devices. The OPS server needs to be installed and running before configuring solutions on these devices.
Note: All devices that support OXPd v1.0 are also compatible with OXPd v1.8.4.
Device |
OXPd Java/.Net |
OXPd JavaScript |
| HP Color LaserJet Enterprise MFP 6800/6801 | X | X |
| HP Color LaserJet Enterprise MFP X58045 | X | X |
| HP Color LaserJet Enterprise 6700/6701 | X | X |
| HP Color LaserJet Enterprise MFP 5800 | X | X |
| HP Color LaserJet Enterprise 5700 | X | X |
| HP LaserJet Enterprise MFP M637 | X | X |
| HP Color LaserJet Enterprise MFP M480 | X | X |
| HP Color LaserJet Enterprise M455 | X | X |
| HP LaserJet Enterprise MFP M430/M431 | X | X |
| HP LaserJet Enterprise M406, M407 | X | X |
| HP Color LaserJet Enterprise MFP M578 | X | X |
| HP Color LaserJet Enterprise M554/M555 | X | X |
| HP Color LaserJet Enterprise MFP X677/X67755/X67765 | X | X |
| HP Color LaserJet Enterprise X654/X65455/X65465 | X | X |
| HP Color LaserJet Enterprise MFP X57945 | X | X |
| HP Color LaserJet Enterprise X55745 | X | X |
| HP Color LaserJet Managed MFP E47528 | X | X |
| HP Color LaserJet Managed E45028 | X | X |
| HP LaserJet Managed MFP E42540 | X | X |
| HP LaserJet Managed E40040 | X | X |
| HP Color LaserJet Managed MFP E785 | X | X |
| HP Color LaserJet Managed MFP E78523/E78528 | X | X |
| HP LaserJet Managed MFP E730 | X | X |
| HP LaserJet Managed MFP E73025/E73030 | X | X |
| HP Color LaserJet Managed MFP E786 | X | X |
| HP Color LaserJet Managed MFP E78625/E78630/E78635 | X | X |
| HP LaserJet Managed MFP E731 | X | X |
| HP LaserJet Managed MFP E73130/E73135/E73140 | X | X |
| HP Color LaserJet Managed MFP E877 | X | X |
| HP Color LaserJet Managed MFP E87740/E87750/E87760/E87770 | X | X |
| HP LaserJet Managed MFP E826 | X | X |
| HP LaserJet Managed MFP E82650/E82660/E82670 | X | X |
| HP Color LaserJet Managed MFP E78223/E78228 | X | X |
| HP Color LaserJet Managed MFP E78323/E78325/E78330 | X | X |
| HP LaserJet Enterprise MFP M634/M635/M636 | X | X |
| HP LaserJet Enterprise M610/M611/M612 | X | X |
| HP LaserJet Managed E40040dn | X | X |
| HP LaserJet Managed MFP E42540f | X | X |
| HP Color LaserJet Managed E45028dn | X | X |
| HP Color LaserJet Managed MFP E47528f | X | X |
| HP LaserJet Enterprise M406dn/M407dn | X | X |
| HP Color LaserJet Enterprise MFP M480f | X | X |
| HP PageWide Enterprise Color 755 | X | X |
| HP PageWide Enterprise Color 765 | X | X |
| HP PageWide Enterprise Color 774 *** Requires Futuresmart FW version 4.9+ | X | X |
| HP PageWide Enterprise Color MFP 779 *** Requires Futuresmart FW version 4.9+ | X | X |
| HP PageWide Enterprise Color MFP 780 / HP PageWide Enterprise Color Flow MFP 785 | X | X |
| HP PageWide E77650/ E77660 | X | X |
| HP Digital Sender Flow 8500 fn2 | X | X |
| HP ScanJet Enterprise Flow N9120 fn2 | X | X |
| HP LaserJet E52545 MFP / HP LaserJet Flow E52545 MFP | X | X |
| HP LaserJet E50045 | X | X |
| HP LaserJet Managed E50145 | X | X |
| HP LaserJet Managed E60155 series/ E60165 series/ E60175 series | X | X |
| HP Color LaserJet E55040 | X | X |
| HP Color LaserJet E65150/ E65160 | X | X |
| ** HP Officejet Pro 251 dw SFP | X | |
| ** HP Officejet Pro 276 dw MFP | X | |
| ** HP Officejet Pro x476 dw/dn MFP | X | |
| ** HP Officejet Pro x551 dW SFP | X | |
| ** HP Officejet Pro x576dw MFP | X | |
| ** HP OfficeJet Pro 8730 / 8740 All-in-One Printer | X | |
| ** HP PageWide Pro M477 MFP | X | |
| ** HP PageWide Pro 577 MFP, HP PageWide Managed MFP P57750 | X | |
| ** HP PageWide Pro 552 Printer, HP PageWide Managed P55250 | X | |
| ** HP PageWide Pro 750, HP PageWide Managed P75050 | X | |
| ** HP PageWide Color 755 | X | |
| ** HP PageWide Managed Color P75250 | X | X |
| ** HP PageWide Managed Color P77440 | X | X |
| ** HP PageWide Pro 772/777 MFP | X | |
| HP PageWide Managed P77740/P77750/P77760 MFP | X | X |
| HP PageWide Managed P77940/P77950/P77960 MFP *** Requires Futuresmart FW version 4.9+ | X | X |
| LaserJet M5035 MFP / LaserJet M5039 MFP | X | X |
| LaserJet M3035 MFP * | X | X |
| HP Color LaserJet CM4730 MFP * | X | X |
| HP LaserJet M4345 MFP / LaserJet M4349 MFP | X | X |
| HP LaserJet M9040 MFP / LaserJet M9050 MFP / LaserJet M9059 MFP * | X | X |
| HP Color LaserJet CM6030 MFP / Color LaserJet CM6040 MFP / Color LaserJet CM6049 MFP * | X | X |
| HP Digital Sender 9250C * | X | X |
| HP LaserJet M5025 MFP * | X | X |
| HP LaserJet M3027 MFP * | X | X |
| HP Color LaserJet CM3530 MFP * | X | X |
| HP Color LaserJet M575 MFP / HP Color LaserJet Flow M575 | X | X |
| HP LaserJet M525 MFP / HP LaserJet Flow M525 MFP | X | X |
| HP Scanjet Enterprise 8500 | X | X |
| HP Color LaserJet CM4540 MFP | X | X |
| HP LaserJet M4555 MFP | X | X |
| HP Color LaserJet M775 MFP | X | X |
| HP LaserJet Enterprise M830 MFP | X | X |
| HP Color LaserJet Enterprise Flow M880 MFP | X | X |
| HP LaserJet M725 MFP | X | X |
| HP Color LaserJet Enterprise M680 Flow and Non-Flow MFP | X | X |
| HP LaserJet M630 MFP / HP LaserJet Flow M630 MFP | X | X |
| OfficeJet Enterprise X585 Color Flow and Non-Flow MFP | X | X |
| HP LaserJet M712 | X | X |
| HP Color LaserJet M855 | X | X |
| HP Color LaserJet M856 | X | X |
| HP LaserJet M806 | X | X |
| HP Color LaserJet M551 | X | X |
| HP LaserJet M601/M602/M603 | X | X |
| HP Color LaserJet CP 5525 | X | X |
| HP Color LaserJet M651 | X | X |
| HP Color LaserJet M750 | X | X |
| HP Color LaserJet Enterprise M751 | X | X |
| HP Color Officejet X555 MFP | X | X |
| HP Color LaserJet M552 / M553 | X | X |
| HP LaserJet M604 / M605 / M606 | X | X |
| HP LaserJet M506 | X | X |
| HP LaserJet M507 | X | X |
| HP LaserJet M527 MFP | X | X |
| HP LaserJet Enterprise MFP M528/ Flow MFP M528 | X | X |
| HP Color LaserJet M577 MFP | X | X |
| HP PageWide Enterprise Color / Color Flow MFP 586, HP PageWide Managed Color / Color Flow MFP E58650 | X | X |
| HP PageWide Enterprise Color 556, HP PageWide Managed Color E55653 | X | X |
| HP LaserJet Managed Flow MFP E72525/E72530/E72535 | X | X |
| HP Color LaserJet Managed E75245 | X | X |
| HP LaserJet Managed Flow MFP E82540/E82550/E82560 | X | X |
| HP Color LaserJet Managed Flow MFP E77822/E77825/E77830 | X | X |
| HP Color LaserJet Managed Flow E87640/E87650/E87660 | X | X |
| HP Color LaserJet Enterprise M652/M653 | X | X |
| HP Color LaserJet Managed E65050/E65060 | X | X |
| HP LaserJet Enterprise Flow M631/ M632/ M633 MFP | X | X |
| HP LaserJet Managed E62555/E62565 Flow/ E62575 Flow MFP | X | X |
| HP LaserJet Managed E62665/E62665 Flow MFP | X | X |
| HP LaserJet Managed MFP E62655/E62675 Flow MFP | X | X |
| HP Color LaserJet Enterprise M681 Flow MFP | X | X |
| HP Color LaserJet Managed E67550 MFP | X | X |
| HP LaserJet Enterprise M607/M608/M609 | X | X |
| HP LaserJet Managed E60055/E60065/E60075 | X | X |
| HP LaserJet Managed MFP E72425/ E72430 | X | X |
| HP Color LaserJet Managed E67650/E67660 MFP | X | X |
| HP Color Laserjet Enterprise M776 MFP | X | X |
| HP Color LaserJet Managed MFP E77422/ HP Color LaserJet Managed MFP E77428 | X | X |
| HP Color LaserJet MFP E78223 | X | X |
| HP Color LaserJet Managed E85055 | X | X |
In this release, the EIP SDK version has been upgraded to 5.1.1 and is backward compatible. There are many different Xerox devices that support EIP. The following table shows which devices support EIP and their versions 3.7, 5.0, 5.1, or 5.1.1 including versions 1.0, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.1, 4.2 and 4.3. In some cases, the device may need to be at a minimum firmware level for EIP support. The recommendation is to always be at the latest version of the firmware.
Device |
EIP Version |
| Xerox® VersaLink® C405 Color Multifunction Printer * | 3.7 | Not Required |
| Xerox® VersaLink® C400 Color Printer | 3.7 | Not Required |
| Xerox® VersaLink® C500 Printer | 3.7 | Not Required |
| Xerox® VersaLink® C600 Printer | 3.7 | Not Required |
| Xerox® VersaLink® C505 Color Multifunction Printer * | 3.7 | Not Required |
| Xerox® VersaLink® C605 Color Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® B400 Printer | 3.7 | Not Required |
| Xerox® VersaLink® B405 Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® B600 Printer | 3.7 | Not Required |
| Xerox® VersaLink® B610 Printer | 3.7 | Not Required |
| Xerox® VersaLink® B605 Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® B615 Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® B7025/B7030/B7035 Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® C7000/C7020/C7025/C7030 Color Multifunction Printer | 3.7 | Not Required |
| Xerox® VersaLink® C7120/C7125/C7130 Multifunction Printer* | 3.7 | Not Required |
| Xerox® VersaLink® B7125/B7130/B7135 Multifunction Printer* | 3.7 | Not Required |
| Xerox® VersaLink® C8000 Printer | 3.7 | Not Required |
| Xerox® VersaLink® C9000 Printer | 3.7 | Not Required |
| Xerox® PrimeLink™ C9065/C9070 Printer | 3.7 | Not Required |
| Xerox® PrimeLink® B9100/B9110/B9125/B9136 Copier/Printer | 3.7 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 5.0 | EIP 4.3, 118.xxx.xxx.xxxxx |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 5.0 | EIP 4.3, 118.xxx.xxx.xxxxx |
| Xerox® VersaLink® B625 Multifunction Printer* | 5.1 | Not Required |
| Xerox® VersaLink® C625 Multifunction Printer* | 5.1 | Not Required |
| Xerox® VersaLink® B415 Multifunction Printer* | 5.1 | Not Required |
| Xerox® VersaLink® C415 Multifunction Printer* | 5.1 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 5.1 | EIP 5.0, 119.xxx.xxx.xxxxx |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 5.1 | EIP 5.0, 119.xxx.xxx.xxxxx |
| Xerox® VersaLink® B625 Multifunction Printer* | 5.1.1 | EIP 5.1.1, 120.025.003.20000 |
| Xerox® VersaLink® C625 Multifunction Printer* | 5.1.1 | EIP 5.1.1, 120.024.003.20000 |
| Xerox® VersaLink® B415 Multifunction Printer* | 5.1.1 | EIP 5.1.1, 120.029.003.20000 |
| Xerox® VersaLink® C415 Multifunction Printer* | 5.1.1 | EIP 5.1.1, 120.028.003.20000 |
| Xerox® VersaLink® B620 Printer* | 5.1.1 | Not Required |
| Xerox® VersaLink® C620 Color Printer* | 5.1.1 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 5.1.1 | EIP 5.1, 120.xxx.xxx.xxxxx |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 5.1.1 | EIP 5.1, 120.xxx.xxx.xxxxx |
| Xerox® Color 550/560 Printer | 1.0 | Not Required |
| Xerox® C60/C70 | 1.0 | Not Required |
| Xerox® D95/D110/D125/D136 | 1.0 | Not Required |
| ColorQube® 9201/9202/9203 | 1.0 | (North America) 060.050.009.03614 (Europe) 060.050.009.13415 |
| Phaser 3635 MFP | 1.0 | 20.103.05.000 |
| WorkCentre® 232/238/245/255/265/275 | 1.0 |
13.060.17.000 May require hardware upgrade |
| WorkCentre® Pro 232/238/245/255/265/275 | 1.0 |
14.060.17.000 May require hardware upgrade |
| WorkCentre® 5135/5150 | 1.0 | Hardware Enablement Kit Required |
| WorkCentre® 5222/5225/5230 | 1.0 | 1.204.4 |
| WorkCentre® 5325/5330/5335 | 1.0 | Not Required |
| WorkCentre® 5632/5638/5645/5655/5665/5675/5687 | 1.0 |
(Multi Board Controller) 21.113.02 |
| WorkCentre® 6400 | 1.0 | 060.070.109.11407 |
| WorkCentre® 7120/7125 | 1.0 | Not Required |
| Xerox® Color 550/560 Printer | 1.5 | Not Required |
| Xerox® C60/C70 | 1.5 | Not Required |
| Xerox® D95/D110/D125/D136 | 1.5 | Not Required |
| ColorQube® 9201/9202/9203 | 1.5 | (North America) 060.050.009.24419 (Europe) 060.050.009.30823 |
| WorkCentre® 5135/5150 | 1.5 | Hardware Enablement Kit Required |
| WorkCentre® 5325/5330/5335 | 1.5 | Not Required |
| WorkCentre® 5632/5638/5645/5655/5665/5675/5687 | 1.5 |
(Single Board Controller) 25.054.053.000 (Multi Board Controller) 21.120.052.000 |
| WorkCentre® 6400 | 1.5 | 061.070.100.24201 |
| WorkCentre® 7120/7125 | 1.5 | 71.3.1 |
| WorkCentre® 7232/7242 | 1.0 | 1.203.5 |
| WorkCentre® 7328/7335/7345 | 1.0 | 1.221.5 |
| WorkCentre® 7346 | 1.0 | 1.224.1 |
| WorkCentre® 7425/7428/7435 | 1.0 | 74.1.3 |
| WorkCentre® 7655/7665/7675 | 1.0 | (Base) 040.033.50500 (Low Cost Device) 040.033.52800 |
| WorkCentre® 7755/7765/7775 | 1.0 | Not Required |
| Xerox® 4112/4127 | 1.0 | Not Required |
| Xerox® Versant® 180 Press | 1.0 | Not Required |
| Xerox® Versant® 280 Press | 1.0 | Not Required |
| WorkCentre® 7425/7428/7435 | 1.5 | 75.3.1 |
| WorkCentre® 7655/7665/7675 | 1.5 | 040.033.53050 |
| WorkCentre® 7755/7765/7775 | 1.5 | 060.090.009.23712 |
| Xerox® 4112/4127 | 1.5 | Not Required |
| Xerox® Versant® 180 Press | 1.5 | Not Required |
| Xerox® Versant® 280 Press | 1.5 | Not Required |
| WorkCentre® 5735/5740/5745/5755/5765/5775/5790 | 2.0 | 061.132.221.29100 |
| WorkCentre® 7525/7530/7535/7545/7556 | 2.0 | 061.121.221.20901 |
| ColorQube® 9301/9302/9303 | 2.0 | 071.180.203.05402 |
| ColorQube® 8700/8900 | 2.0 | 071.160.101.xxx |
| WorkCentre® 7830/7835 | 2.0 | Not Required |
| WorkCentre® 7845/7855 | 2.0 | Not Required |
| WorkCentre® 58xx | 2.0 | Not Required |
| WorkCentre® 7220/7225 | 2.0 | Not Required |
| WorkCentre® 5945/5955 | 2.0 | Not Required |
| WorkCentre® 6655 | 2.0 | Not Required |
| WorkCentre® 3655X | 2.0 | Not Required |
| WorkCentre® 7970 | 2.0 | Not Required |
| ColorQube® 9301/9302/9303 | 2.5 | 071.180.203.05402 |
| ColorQube® 8700/8900 | 2.5 | 071.161.203.09300 |
| WorkCentre® 7830/7835 | 2.5 | 071.010.102.34900 |
| WorkCentre® 7845/7855 | 2.5 | 071.010.102.34900 |
| WorkCentre® 58xx | 2.5 | 071.190.102.34907 |
| WorkCentre® 7220/7225 | 2.5 | 071.030.103.04401 |
| WorkCentre® 5945/5955 | 2.5 | Not Required |
| WorkCentre® 6655 | 2.5 | Not Required |
| WorkCentre® 3655X | 2.5 | Not Required |
| WorkCentre® 7970 | 2.5 | Not Required |
| WorkCentre® 4265 | 2.0 | Not Required |
| WorkCentre® 4265 | 2.5 | Not Required |
| ColorQube® 9301/9302/9303 | 3.0 | 072.180.004.09101 |
| ColorQube® 8700/8900 | 3.0 | 072.162.004.09100 |
| WorkCentre®7830/7835 | 3.0 | 072.010.004.09100 |
| WorkCentre® 7845/7855 | 3.0 | 072.040.004.09100 |
| WorkCentre® 58xx | 3.0 | 072.190.004.09101 |
| WorkCentre® 7220/7225 | 3.0 | 072.030.004.09100 |
| WorkCentre® 5945/5955 * | 3.0 | 072.091.054.31606 |
| WorkCentre® 6655 * | 3.0 | Not Required |
| WorkCentre® 3655X | 3.0 | Not Required |
| WorkCentre® 7970 | 3.0 | Not Required |
| WorkCentre®7830/7835 | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 7845/7855 | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 58xx | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 7220/7225 | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 5945/5955 * | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 6655 * | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 3655X | 3.5 | 073.xxx.075.34540 |
| WorkCentre® 7970 | 3.5 | 073.xxx.075.34540 |
| Xerox® AltaLink® B8045 / B8055 / B8065 / B8075 / B8090 Multifunction Printer * | 3.7 | Not Required |
| Xerox® AltaLink® C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer * | 3.7 | Not Required |
| Xerox® EC8036/EC8056 Color Multifunction Printer * | 3.7 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 3.7 | Not Required |
| Xerox® AltaLink® B8045 / B8055 / B8065 / B8075 / B8090 Multifunction Printer * | 4.0 | Not Required |
| Xerox® AltaLink® C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer * | 4.0 | Not Required |
| Xerox® EC8036/EC8056 Color Multifunction Printer * | 4.0 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 4.0 | Not Required |
| Xerox® AltaLink® B8045 / B8055 / B8065 / B8075 / B8090 Multifunction Printer * | 4.1 | Not Required |
| Xerox® AltaLink® C8030 / C8035 / C8045 / C8055 / C8070 Color Multifunction Printer * | 4.1 | Not Required |
| Xerox® EC8036/EC8056 Color Multifunction Printer * | 4.1 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 4.1 | Not Required |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 3.7 | Not Required |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 4.0 | Not Required |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 4.1 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 4.2 | Not Required |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * ✓ | 4.2 | Not Required |
| Xerox® AltaLink® C8130/35/45/55/70 Color Multifunction Printer * | 4.3 | 14.xxx.001.27300 |
| Xerox® AltaLink® B8145/55/70 Multifunction Printer * | 4.3 | 114.xxx.001.27300 |
Note: VersaLink EIP 5.0 or higher devices will behave differently than EIP 3.7 due to a new engine on those devices.
OXPdJava/.Net |
OXPd Javascript |
| HP LaserJet Enterprise MFP M430f/M431f | X | X |
| HP Color LaserJet Enterprise M455dn | X | X |
| HP Color LasertJet Enterprise MFP M480f | X | X |
| HP PageWide Enterprise Color MFP 779 *** Requires Futuresmart FW version4.9+ | X | X |
| HP PageWide Enterprise Color MFP 780 / HP PageWide Enterprise Color FlowMFP 785 | X | X |
| HP Color LaserJet E52645 MFP /HP Color LaserJet Flow E52645 MFP | X | X |
| HP Color LaserJet E57540 MFP / HP Color LaserJet Flow E57540 MFP | X | X |
| HP PageWide Managed P77940/P77950/P77960 MFP *** RequiresFuturesmart FW version 4.9+ | X | X |
| HP Color LaserJet CM6030 MFP / Color LaserJet CM6040 MFP / Color LaserJetCM6049 MFP * | X | X |
| HP PageWide Enterprise Color / Color Flow MFP 586, HP PageWide ManagedColor / Color Flow MFP E58650 | X | X |
| HP LaserJet Managed E62665/ E62665 Flow MFP | X | X |
| HP LaserJet Managed MFP E62655/ E62675 Flow MFP | X | X |
| HP Color LaserJet Managed MFP E77422/ HP Color LaserJet Managed MFPE77428 | X | X |
** OXPd version 1.7 is required on Pro devices. Later versions of OXPd are not supported. OXPd ProServices (OPS) is required to enable OXPd solutions on OfficeJet Pro devices. The OPS server needs to be installed and running before configuring solutions on these devices.
eSF Version 7
fw - framework
NA - Not Applicable
Derivative Model |
Family Category |
| CX730de | XC4342 |
| CX94x | XC94xx |
| CX93x | XC93xx |
| MX931x | NA |
| MX43x | XM31xx |
| MX53x | NA |
| MX63x | XM3350 |
| CX53x | NA |
| CX63x | NA |
The table includes model number, device category and SDK version.
Category |
SDK Version |
| IM 370/370F/460F/460FTL | MFP | 5.0 |
| IM C2010/C2510/C2519/C3010/C3510/C3519/C4510/C5510/C6010 | MFP | 5.0 |
| IM 2500 IM 3000 IM 3500 IM 4000 IM 5000 IM 6000 | MFP | 3.2 |
| IM 7000 IM 8000 IM 9000 IM 9000T | MFP | 3.2 |
| IM C530 IM C530B | MFP | 2.71 |
| Pro C5300S Pro C5310S | MFP Pro | 3.2 |
| IM C6500 IM C8000 | MFP | 3.2 |
| IM 2702 | MFP | 2.5 |
| IM C300 IM C400 | MFP | 2.5 |
| IM 550F IM 600SRF | MFP | 3.2 |
| Pro 8300s Pro 8310s Pro 8320s | MFP Pro | 2.5 |
| Pro 8310 Pro 8320 | MFP Pro | 2.5 |
| IM 350F IM 430F | MFP | 2.50 |
| IM 430Fb | MFP | 2.50 |
| IM C3000 IM C3500 IM C4500 IM C6000 | MFP | 2.50 |
| IM C2000 IM C2500 | MFP | 2.50 |
| MP C501SP | MFP | 2.41 |
| SP C360SFNw | MFP | 2.31 |
| SP C361SFNw | MFP | 2.31 |
| MP C3004exSP MP C3504exSP | MFP | 2.71 |
| MP C4504exSP | MFP | 2.71 |
| MP C6004exSP | MFP | 2.71 |
| SP 8400DN | MFP | 2.41 |
| MP C4504exASP MP C6004exASP | MFP | 2.71 |
| MP C3004exASP MP C3504exASP | MFP | 2.71 |
| MP C2004ex MP C2504ex | MFP | 2.71 |
| MP 9003 | MFP | 2.50 |
| MP 6503 MP 7503 | MFP | 2.50 |
| SP C840DN SP C842DN | MFP | 2.50 |
| MP 2555SP MP 3055SP MP 3555SP MP 4055SP MP 5055SP MP 6055SP | MFP | 2.50 |
| MP C307ZSPF MP C407ZSPF | MFP | 2.50 |
| MP C6503 MP C8003 | MFP | 2.50 |
| MP 402SPF | MFP | 2.50 |
| MP C2004SP MP C2504SP | MFP | 2.71 |
| MP 6503SP MP 7503SP | MFP | 2.50 |
| MP 9003SP | MFP | 2.50 |
| MP C3004SP MP C3504SP MP C4504SP MP C6004SP | MFP | 2.71 |
| MP 305+SPF | MFP | 2.50 |
Support introduced in |
MFP Device Type |
6.6 |
| HP Color LaserJet Managed MFP E785dn | |
| HP Color LaserJet Managed MFP E785 23 to 28ppm License | |
| HP Color LaserJet Managed MFP E78523dn | |
| HP Color LaserJet Managed MFP E78528dn | |
| HP Color LaserJet Managed MFP E786dn | |
| HP Color LaserJet Managed Flow MFP E786z | |
| HP Color LaserJet Managed MFP E786 Core Printer | |
| HP Color LaserJet Managed MFP E786 25 to 30ppm License | |
| HP Color LaserJet Managed MFP E786 25 to 35ppm License | |
| HP Color LaserJet Managed MFP E786 30 to 35ppm License | |
| HP Color LaserJet Managed MFP E78625dn | |
| HP Color LaserJet Managed MFP E78630dn | |
| HP Color LaserJet Managed MFP E78635dn | |
| HP Color LaserJet Managed Flow MFP E78625z | |
| HP Color LaserJet Managed Flow MFP E78630z | |
| HP Color LaserJet Managed Flow MFP E78635z | |
| HP Color LaserJet Managed MFP E877dn | |
| HP Color LaserJet Managed MFP E877z | |
| HP Color LaserJet Managed MFP E877 Core Printer | |
| HP Color LaserJet Managed MFP E877 40 to 50ppm License | |
| HP Color LaserJet Managed MFP E877 40 to 60ppm License | |
| HP Color LaserJet Managed MFP E877 40 to 70ppm License | |
| HP Color LaserJet Managed MFP E877 50 to 60ppm License | |
| HP Color LaserJet Managed MFP E877 60 to 70ppm License | |
| HP Color LaserJet Managed MFP E877 50 to 70ppm License | |
| HP Color LaserJet Managed MFP E87740dn | |
| HP Color LaserJet Managed MFP E87750dn | |
| HP Color LaserJet Managed MFP E87760dn | |
| HP Color LaserJet Managed MFP E87770dn | |
| HP Color LaserJet Managed Flow MFP E87740z | |
| HP Color LaserJet Managed Flow MFP E87750z | |
| HP Color LaserJet Managed Flow MFP E87760z | |
| HP Color LaserJet Managed Flow MFP E87770z | |
| HP LaserJet Managed MFP E730dn | |
| HP LaserJet Managed MFP E730 25 to 30ppm License | |
| HP LaserJet Managed MFP E73025dn | |
| HP LaserJet Managed MFP E73030dn | |
| HP LaserJet Managed MFP E826dn | |
| HP LaserJet Managed Flow MFP E826z | |
| HP LaserJet Managed MFP E826 Core Printer | |
| HP LaserJet Managed MFP E826 50 to 60ppm License | |
| HP LaserJet Managed MFP E826 50 to 70ppm License | |
| HP LaserJet Managed MFP E826 60 to 70ppm License | |
| HP LaserJet Managed MFP E82650dn | |
| HP LaserJet Managed MFP E82660dn | |
| HP LaserJet Managed MFP E82670dn | |
| HP LaserJet Managed Flow MFP E82650z | |
| HP LaserJet Managed Flow MFP E82660z | |
| HP LaserJet Managed Flow MFP E82670z | |
| HP LaserJet Managed MFP E731dn | |
| HP LaserJet Managed Flow MFP E731z | |
| HP LaserJet Managed MFP E731 Core Printer | |
| HP LaserJet Managed MFP E731 30 to 35ppm License | |
| HP LaserJet Managed MFP E731 30 to 40ppm License | |
| HP LaserJet Managed MFP E731 35 to 40ppm License | |
| HP LaserJet Managed MFP E73130dn | |
| HP LaserJet Managed MFP E73135dn | |
| HP LaserJet Managed MFP E73140dn | |
| HP LaserJet Managed Flow MFP E73130z | |
| HP LaserJet Managed Flow MFP E73135z | |
| HP LaserJet Managed Flow MFP E73140z |
The Upland AccuRoute eSF (Embedded Solutions Framework) application was developed using eSF version 7.0 . The following table lists the Lemark printer models that support eSF. When signing an application, it is certified only against the base model and all the derivatives that belong to the printer series are included automatically.
eSF Version 6 and (5 only deprecated)
Printers in this category with framework version 5 (*fw5) are deprecated and will not work with the Upland AccuRoute eSF application.
Base Model |
Derivative Model |
Family Category |
| CX820x | XC61xx |
android wide screen mfp (multi-function printer) *fw5 fw6 |
| CX825x, CX86x | XC81xx |
android xlarge screen mfp *fw5 fw6 |
| CX72x | XC41xx |
android wide screen mfp *fw5 fw6 |
| MX522x | XM12xx |
android small screen mfp *fw5 fw6 |
| MX62x | XM32xx |
| CX92x | XC92xx |
| MS822de, MS826de | XM53xx |
| MX72x | XM53xx |
| MX82x | XM73xx |
| CX52x | XC22xx |
| CX622x | N/A |
| CX625x | XC42xx |
Notes:
Firmware xx.07y.zzz is running framework version 6.3.
Firmware xx.05y.zzz is running framework version 6.2.
Firmware xx.04y.zzz is running framework version 6.1.
Firmware xx.03y.zzz is running framework version 6.0.
Firmware xx.02y.zzz is running framework version 5.0. eSF version 5 is deprecated and can not be used.
Lexmark limited solutions printers
Limited solutions printers are eSF-capable printers that have predefined supported applications. Other applications cannot be added.
Base Model |
Derivative Model |
Family Category |
| MX421ade, MX521ade MX521de | XM1242 |
Notes:
Firmware xx.02y.zzz is running framework version 5.0. eSF version 5 is deprecated and cannot not be used.
FutureSmart MFP Devices |
Platform |
OXPd Version |
6.5 |
| Color MFP M480, E47528 | 2.0.0 | ||
| FutureSmart Bundle 2503213_016685 | Version 5.3 | 2.0.0 | |
| MFP M430, M431, E42540 | 2.0.0 | ||
| Color MFP E78223, E78228 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063748 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016670 | Version 5.3 | 2.0.0 | |
| Color Flow MFP E78323, E78325, E78330 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063718 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016676 | Version 5.3 | 2.0.0 | |
| Color MFP M578, M578z | 2.0.0 | ||
| FutureSmart Bundle 2411177_063719 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016674 | Version 5.3 | 2.0.0 | |
| MFP M634, M635, M636 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063728 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016691 | Version 5.3 | 2.0.0 | |
| Color MFP M776, Flow MFP M776 | 2.0.0 | ||
| FutureSmart Bundle 411177_063738 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016695 | Version 5.3 | 2.0.0 | |
| MFP E62655, E62665, E62675, E62665z, 62675z | 2.0.0 | ||
| Color MFP E67550, E67560, E67660z | 2.0.0 | ||
| FutureSmart Bundle 2411177_063750 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016690 | Version 5.3 | 2.0.0 | |
| MFP M528, E52645 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063714 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016692 | Version 5.3 | 2.0.0 | |
| Color MFP MFP E77422, E77428 | 2.0.0 | ||
| MFP E72425, E72430 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063727 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016698 | Version 5.3 | 2.0.0 | |
| Color MFP E87660du, E87650du, E87640du | 2.0.0 | ||
| FutureSmart Bundle 2411177_063741 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016689 | Version 5.3 | 2.0.0 | |
| MFP E82560du, E82550du, E82540du | 2.0.0 | ||
| PageWide Color MFP 774, 779 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063747 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016680 | Version 5.3 | 2.0.0 | |
| Color MFP E57540 | 2.0.0 | ||
| MFP E52545 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063753 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016684 | Version 5.3 | 2.0.0 | |
| PageWide Color MFP P77960, P77950, P77940, P77440 | 2.0.0 | ||
| PageWide Color MFP 780, Flow 785, E77650, E77660 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063716 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016700 | Version 5.3 | 2.0.0 | |
| Color MFP/Flow MFP M681, M682, E67550, E67560 | 2.0.0 | ||
| MFP/Flow MFP M631, M632, M633, E62555, E62565, E62575 | 2.0.0 | ||
| Color MFP/Flow MFP E87640, E87650, E87660 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063737 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle Version 5.3 2503213_016669 | Version 5.3 | 2.0.0 | |
| MFP/Flow MFP E82540, E82550, E82560 | 2.0.0 | ||
| Color MFP/Flow MFP E77822, E77825, E77830 | 2.0.0 | ||
| MFP/Flow MFP E72525, E72530, E72535 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063734 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016682 | Version 5.3 | 2.0.0 | |
| PageWide Color MFP/Flow MFP 586, E58650 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000449 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063729 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016677 | Version 5.3 | 2.0.0 | |
| MFP/Flow MFP M527 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000424 | Version 3.9.8 | 2.0.0 | |
| Color MFP/Flow MFP M577 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000422 | Version 3.9.8 | 2.0.0 | |
| MFP/Flow MFP M630 | 2.0.0 | ||
| FutureSmart Bundle 2309046_000291 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle Version 4.11 2411177_063732 | Version 4.11 | 2.0.0 | |
| OfficeJet Ent Color MFP/Flow MFP x585 | 2.0.0 | ||
| FutureSmart Bundle Version 3.9.8 3209055_000425 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle Version 4.11 2411177_063715 | Version 4.11 | 2.0.0 | |
| Color MFP/Flow MFP M680 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000447 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063742 | Version 4.11 | 2.0.0 | |
| Color MFP M880 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000439 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063721 | Version 4.11 | 2.0.0 | |
| MFP M830 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000432 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063726 | Version 4.11 | 2.0.0 | |
| MFP M725 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000445 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063730 | Version 4.11 | 2.0.0 | |
| Flow MFP M525 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000440 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063722 | Version 4.11 | 2.0.0 | |
| Color Flow MFP M575 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000448 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063735 | Version 4.11 | 2.0.0 | |
| Color MFP M775 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000433 | Version 3.9.8 | 2.0.0 | |
| FutureSmart Bundle 2411177_063736 | Version 4.11 | 2.0.0 | |
| Color MFP M575 | 2.0.0 | ||
| M4555 MFP | 2.0.0 | ||
| FutureSmart Bundle 2309055_000438 | Version 3.9.8 | 2.0.0 | |
| CM4540 MFP | 2.0.0 | ||
| FutureSmart Bundle 2309055_000451 | Version 3.9.8 | 2.0.0 | |
| FutureSmart ScanJet and Digital Sender Devices | |||
| Digital Sender Flow 8500 fn2 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063751 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016666 | Version 5.3 | 2.0.0 | |
| ScanJet Flow N9120 fn2 | 2.0.0 | ||
| FutureSmart Bundle 2411177_063746 | Version 4.11 | 2.0.0 | |
| FutureSmart Bundle 2503213_016681 | Version 5.3 | 2.0.0 | |
| ScanJet Enterprise 8500 FN1 | 2.0.0 | ||
| FutureSmart Bundle 2309055_000437 | Version 3.9.8 | 2.0.0 |
The Upland AccuRoute MEAP (Multifunctional Embedded Application Platform) application was developed using the MEAP SDK version 5.7 and is backward compatible. See a list of supported Canon devices below.
| MFP Devices Only | |||
| imageRUNNER Advance 8505 | imageRUNNER Advance 715iF /715iFZ II | imageRUNNER Advance C356iF III | DX C5750i |
| imageRUNNER Advance 8595 | imageRUNNER Advance 615iF/615iFZ II | imageRUNNER Advance C256iF III | DX 6000i |
| imageRUNNER Advance 8585 | imageRUNNER Advance 525iF/525iFZ II | imageRUNNER Advance C475iF III and C475iFZ III | |
| imageRUNNER Advance 6575 | imageRUNNER Advance C7580 III | imageRUNNER Advance 715iF III and 715FZ III | |
| imageRUNNER Advance 6565 | imageRUNNER Advance C7570 III | imageRUNNER Advance 615iF III and 615FZ III | |
| imageRUNNER Advance 6555 | imageRUNNER Advance C7565 III | imageRUNNER Advance 525iF III and 525FZ III | |
| imageRUNNER Advance C5560i | imageRUNNER Advance C8505i III | DX 8705i | |
| imageRUNNER Advance C5550i | imageRUNNER Advance 8595 III | DX 8795i | |
| imageRUNNER Advance C5540i | imageRUNNER Advance 6575i III | DX 8786i | |
| imageRUNNER Advance C5535i | imageRUNNER Advance 6565i III | DX C7780i | |
| imageRUNNER Advance C7580i | imageRUNNER Advance 6555i III | DX C7770i | |
| imageRUNNER Advance C7570i | imageRUNNER Advance C5560i III | DX C7765 | |
| imageRUNNER Advance C7565i | imageRUNNER Advance C5550i III | DX C3730i | |
| imageRUNNER Advance 4551 | imageRUNNER Advance C5540i III | DX C3725i | |
| imageRUNNER Advance 4545i | imageRUNNER Advance C5535i III | DX 6780i | |
| imageRUNNER Advance 4535i | imageRUNNER Advance 4551i III | DX 6765i | |
| imageRUNNER Advance 4525i | imageRUNNER Advance 4545i III | DX 6755i | |
| imageRUNNER Advance C355iF | imageRUNNER Advance 4535i III | DX 4751i | |
| imageRUNNER AdvanceC255iF | imageRUNNER Advance 4525i III | DX 4745i | |
| imageRUNNER Advance C3530i | imageRUNNER Advance C3525i III | DX 4735i | |
| imageRUNNER Advance C3525i | imageRUNNER Advance C3530i III | DX 4725i | |
| Platform |
Model |
Type |
| IM C8000 | G2.5 Android Panel | |
IM C6500 |
| IM C530 | G2.5 Android Panel | |
| 12.XX | SP C361SFNw | G2.0 Android Panel |
| 12.XX | IM 350 | G2.0 Android Panel |
| 12.XX | IM 350F | G2.0 Android Panel |
| 12.XX | IM 430F | G2.0 Android Panel |
| 12.XX | IM 430Fb | G2.0 Android Panel |
| 12.XX | IM C2000 | G2.5 Android Panel |
| 12.XX | IM C2500 | G2.5 Android Panel |
| 12.XX | IM C3000 (E25C) | G2.5 Android Panel |
| 12.XX | IM C3500 (E25C) | G2.5 Android Panel |
| 12.XX | IM C4500 (E25C) | G2.5 Android Panel |
| 12.XX | IM C5500 (E25C) | G2.5 Android Panel |
| 12.XX | IM C6000 (E25C) | G2.5 Android Panel |
| 12.XX | MP C6503 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP C8003 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro C5200S (e24b / e44b) | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro C5210S (e24b / e44b) | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro 8300S | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro 8310S | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro8320S | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro 8310 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | Pro 8320 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP C501SP | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 6503SP | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 7503SP | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 9003SP | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 305SPF | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 601SPF | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP C307SPF | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP C407SPF | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 2555 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 3055 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 3555 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 4055 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 5055 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP 6055 | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | SP C840dn | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | SP C842dn | SmartOp Panel Devices - Android Gen 2 |
| 12.XX | MP C402 | SmartOp Panel - Android Gen 1 |
| 12.XX | SP 8400dn | |
| 12.XX | SP C435DN | |
| 12.XX | SP 342DN | |
| 10.XX | MP 2501SP |
Device |
Base Firmware |
Minimum Firmware for SHA-256 |
Recommended Upgrade |
| ColorQube 8700/8900 | 072.162.004.09100 | 071.160.101.35100 | 072.162.004.09100 |
| ColorQube 9210/9202/9203 | 060.050.009.30823 | None | None |
| ColorQube 9301/9302/9303 | 072.180.203.05402 | 071.180.203.05402 | 072.180.004.09101 |
| Phaser 3635 MFP | 20.107.01.000 | 20.107.01.000 | 20.107.01.000 |
| WorkCentre Pro 232/238/245/255/265/276 | 14.060.17.000 | None | None |
| WorkCentre 3655 | 073.060.019.14200 | N/A | N/A |
| WorkCentre 4265 | 50.004.00.000 | 50.003.03.000 | 50.004.00.000 |
| WorkCentre 5135/5150 | N/A | None | None |
| WorkCentre 5222/5225/5230 | 1.227.8 | None | None |
| WorkCentre 5325/5330/5335 | 53.30.11 | 53.33.32 | 54.34.23 |
| WorkCentre 5632/5638/5645/5655/5665/5675/5687 | 21.113.02.000 | None | None |
| WorkCentre 5735/5740/5745/5755/5765/5775/5790 | 061.132.221.21403 | 61.132.221.21403 | 61.132.221.21403 |
| WorkCentre 58xx | 071.190.102.34907 | N/A | N/A |
| WorkCentre 5945/5955 | 072.091.054.31606 | N/A | N/A |
| WorkCentre 6400 | 061.070.100.24201 | None | None |
| WorkCentre 6655 | 073.110.019.14200 | N/A | N/A |
| WorkCentre 7120/7125 | 71.21.21 | 71.24.12 | 71.24.23 |
| WorkCentre 7220/7225 | 072.030.004.09101 | N/A | N/A |
| WorkCentre 7232/7242 | Only supported via device management app for remote services | None | None |
| WorkCentre 7328/7335/7345 | Only supported via device management app for remote services | None | None |
| WorkCentre 7346 | Only supported via device management app for remote services | None | None |
| WorkCentre 7425/7428/7435 | Only supported via device management app for remote services | None | None |
| WorkCentre 7525/7530/7535/7545/7556 | 061.121.223.09002 | 061.121.223.09002 | 061.090.229.14300 |
| WorkCentre 7655/7665/7675 | Only supported via device management app for remote services | None | None |
| WorkCentre 7755/7765/7775 | 061.090.226.13100 | 061.090.226.13100 | 061.090.229.14300 |
| WorkCentre 7830/7835 | 072.010.004.09100 | N/A | N/A |
| WorkCentre 7845/7855 | 072.040.004.09100 | N/A | N/A |
| WorkCentre 7970 | 072.200.024.14107 | N/A | N/A |
| Xerox Color 550/560 Printer | 55.42.33 | 55.42.33 | 55.42.73 |
| Xerox C60/C70 | 60.30.51 | 60.30.51 | 60.30.52 |
| Xerox D95/D110/D125/D136 | SFR 25.13.02 | SFR 25.13.02 | SFR 25.14.31 |
| Xerox 4112/4127 | N/A | None | None |
| Xerox AltaLink B8045/B8055/B8065/B8075/B8090 Multifunction Printer | 101.008.019.20200 | N/A | N/A |
| Xerox AltaLink C8030/B8035/B8045/B8055/B8070 Color Multifunction Printer | 101.002.019.20200 | N/A | N/A |
| Xerox VersaLink C405 Color Multifunction Printer | 68.50.61 | N/A | N/A |
| Xerox VersaLink C505 Color Multifunction Printer | 62.50.61 | N/A | N/A |
| Xerox VersaLink C605 Color Multifunction Printer | 62.50.61 | N/A | N/A |
| Xerox VersaLink B405 Multifunction Printer | 68.50.61 | N/A | N/A |
| Xerox VersaLink B605 Multifunction Printer | 62.50.61 | N/A | N/A |
| Xerox VersaLink B615 Multifunction Printer | 33.50.71 | N/A | N/A |
| Xerox VersaLink B7025/B7030/B7035 Multifunction Printer | 58.50.61 | N/A | N/A |
Devices |
Supported Firmware |
OXPd Version |
6.4 |
| HP Color LaserJet Enterprise MFP M480f, HP Color LaserJet Managed MFP E47528f | FS5 (JoLT) | 1.9.0 | |
| HP Color LaserJet Enterprise M455dn, HP Color LaserJet Managed E45028dn | FS5 (JoLT) | 1.9.0 | |
| HP LaserJet Enterprise MFP M430f, HP LaserJet Enterprise MFP M431f (CH/IN), HP LaserJet Managed MFP E42540f | FS5 (JoLT) | 1.9.0 | |
| HP LaserJet Enterprise M406dn, HP LaserJet Enterprise M407dn (CH/IN), HP LaserJet Managed E40040dn | FS5 (JoLT) | 1.9.0 | |
| Color LJ Managed MFP E78223/E78228 | FS5 (JoLT) | 1.9.0 | |
| Color LJ Managed Flow MFP E78323/E78325/E78330 | FS5 (JoLT) | 1.9.0 | |
| HP LJ M610, M611, M612 | FS5 (JoLT) | 1.9.0 | |
| HP LJ MFP M634, M635, M636 | FS5 (JoLT) | 1.9.0 |
Devices |
OXPd Version |
6.3 |
Future Smart Devices | ||
| Color MFP M776, Flow MFP M776 | 2409065_000052 (4.9.0.1) | 1.8.0 | |
| MFP M528, E52645 | 2409065_000054 (4.9.0.2) | 1.8.0 | |
| MFP E62655, E62665, E62675 | 2409065_000074 (4.9.0.2) | 1.8.0 | |
| Color MFP E67550, E67560 | 2409058_053367 (4.9.0.1) | 1.8.0 | |
| MFP E72425, E72430 | 2409058_053364 (4.9.0.1) | 1.8.0 | |
| Color MFP MFP E77422, E77428 | 2409058_053344 (4.9.0.1) | 1.8.0 | |
| Color MFP E87660du, E87650du, E87640du | 2409058_053353 (4.9.0.1) | 1.8.0 | |
| MFP E82560du, E82550du, E82540du | 2409058_053349 (4.9.0.1) | 1.8.0 | |
| Color MFP E57540 | 2409058_053388 (4.9.0.1) | 1.8.0 | |
| MFP E52545 | 2409065_000073 (4.9.0.2) | 1.8.0 | |
| PageWide Color MFP P77960, P77950, P77940, P77440, 774, 779 | 2409058_053389 (4.9.0.1) | 1.8.0 | |
| PageWide Color MFP 780, Flow 785, E77650, E77660 | 2409058_053390 (4.9.0.1) | 1.8.0 | |
| Digital Sender Flow 8500 fn2 | 2409058_053351 (4.9.0.1) | 1.8.0 | |
| ScanJet Flow N9120 fn2 | 2409058_053376 (4.9.0.1) | 1.8.0 | |
| MFP/Flow MFP M631, M632, M633, E625xx | 2409065_000074 (4.9.0.2) | 1.8.0 | |
| Color MFP/Flow MFP M681, M682, E675xx | 2409058_053367 (4.9.0.1) | 1.8.0 | |
| MFP/Flow MFP E72525, E72530, E72535 | 2409058_053356 (4.9.0.1) | 1.8.0 | |
| MFP/Flow MFP E82540, E82550, E82560 | 2409058_053349 (4.9.0.1) | 1.8.0 | |
| Color MFP/Flow MFP E77822, E77825, E77830 | 2409058_053384 (4.9.0.1) | 1.8.0 | |
| Color MFP/Flow MFP E87640, E87650, E87660 | 2409058_053353 (4.9.0.1) | 1.8.0 | |
| PageWide Color MFP//Flow MFP 586 | 2409058_053350 (4.9.0.1), 2309021_581891 (3.9.5) | 1.8.0 | |
| MFP//Flow MFP M527 | 2409065_000073 (4.9.0.2), 2309021_581883 (3.9.5) | 1.8.0 | |
| Color MFP/Flow MFP M577 | 2409058_053388 (4.9.0.1), 2309021_581889 (3.9.5) | 1.8.0 | |
| MFP/Flow MFP M630 | 2409058_053369 (4.9.0.1), 2309021_581882 (3.9.5) | 1.8.0 | |
| OfficeJet Ent Color MFP/Flow MFP x585 | 2409058_053357 (4.9.0.1), 2309021_581884 (3.9.5) | 1.8.0 | |
| Color MFP/Flow MFP M680 | 2409058_053363 (4.9.0.1), 2309021_581900 (3.9.5) | 1.8.0 | |
| MFP M830 | 2409058_053365 (4.9.0.1), 2309021_581896 (3.9.5) | 1.8.0 | |
| Color MFP M880 | 2409058_053354 (4.9.0.1), 2309021_581898 (3.9.5) | 1.8.0 | |
| MFP M725 | 2409058_053358 (4.9.0.1), 2309021_581904 (3.9.5) | 1.8.0 | |
| Flow MFP M525 | 2409058_053378 (4.9.0.1), 2309021_581897 (3.9.5) | 1.8.0 | |
| Color Flow MFP M575 | 2409058_053370 (4.9.0.1), 2309021_581910 (3.9.5) | 1.8.0 | |
2309021_581894 (3.9.5) | 1.8.0 | |
M4555 MFP |
2309021_581901 (3.9.5) | 1.8.0 | |
CM4540 MFP |
2309021_581893 (3.9.5) | 1.8.0 | |
| ScanJet 7000n | Solution is NOT supported on this device. EOSL devices. | ||
| Oz Devices | |||
| CM3530mfp | 53.320.3 (15.1.4) | 1.8.0 | |
| CM6030mfp, 6040mfp | 52.380.4 (15.1.4) | 1.8.0 | |
| M9040mfp, M9050mfp | 51.320.4 (15.1.4) | 1.8.0 | |
| CM4730mfp | Solution is NOT supported on this device. EOSL devices. | ||
| 9250C DS | Solution is NOT supported on this device. EOSL devices. | ||
| CM8050mfp, 8060mfp | Solution is NOT supported on this device. EOSL devices. | ||
| M5035mfp | 48.420.4 (15.1.4) | 1.8.0 | |
| M4345mfp | 48.420.4 (15.1.4) | 1.8.0 | |
| M3035mfp | 48.420.4 (15.1.4) | 1.8.0 | |
| CLJ 4730mfp | Solution is NOT supported on this device. EOSL devices. | ||
| 9200C DS | Solution is NOT supported on this device. EOSL devices. | ||
| LJ 4345mfp | Solution is NOT supported on this device. EOSL devices. | ||
| LJ 9040mfp, 9050mfp | Solution is NOT supported on this device. EOSL devices. | ||
| CLJ 9500mfp | Solution is NOT supported on this device. EOSL devices. | ||
| Pro Devices | |||
| PageWide Pro MFP 772, P77740, P77750, P77760, 777z | 1921A | 1.8.0 | |
| PageWide Pro MFP 477, 577, 57750 | 1850B | 1.8.0 | |
| OfficeJet Pro 8730, 8740 | 1903B | 1.8.0 | |
| Officejet Pro 276 MFP | Solution is NOT supported on this device. EOSL devices. | ||
| Officejet Pro x476 MFP, x576 MFP | 1829B | 1.8.0 | |
| S900 Series Devices | |||
HP MFP S965dn, S975dn |
H1.07.t1.00 | 1.8.0 | |
HP Color MFP S962dn, S970dn |
H1.07.S1.00 | 1.8.0 | |
| HP Color MFP S951dn | H1.07.R2.00 | 1.8.0 | |
| HP MFP S956dn | H1.07.01.00 | 1.8.0 | |
Devices |
Group |
OXPd Version |
6.1 |
HP Officejet Pro X476dn MFP |
LNP1CA1335AR |
1.7.X |
HP LaserJet M4345 MFP |
48.420.4 |
1.7.X |
HP LaserJet MFP E72525 |
2405129_000044 |
1.7.X |
HP Scanjet Enterprise 7000n |
2204081_233277 |
1.7.X |
HP PageWide Color MFP P77440dn |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77940dn |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77940dns |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77940ds+ |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77950dn |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77950dns |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77960dn |
FS 24.5.5 |
1.7.X |
HP PageWide Color MFP P77960dns |
FS 24.5.5 |
1.7.X |
6.0
LNP1CA1335AR |
1.7.3 |
48.420.4 |
1.7.3 |
2204081_233277 |
1.7.3 |
HP ScanJet Flow N9120 fn2 Document Scanner |
2405087_018552 |
1.7.3 |
HP Digital Sender Flow 8500 fn2 Document Capture Workstation |
2405087_018553 |
1.7.3 |
HP PageWide Color MFP 780, Flow 785, E77650, and E77660 Series |
2405087_018548 |
1.7.3 |
5.0
HP LaserJet Enterprise MFP M631/M632/M633/E625xx Series |
2403298_006036 2405129_000041 |
1.7.X |
HP Color LaserJet Enterprise MFP M681/M682/E675xx Series |
2403298_006039 2405129_000037 |
1.7.X |
HP Color LaserJet Managed MFP E87640/ E87650/E87660 Series |
2403300_006052 2403325-000091 |
1.7.X |
HP Color LaserJet Managed MFP E77822/E77825/E77830 Series |
2403293_005974 2403325-000092 |
1.7.X |
HP LaserJet Managed MFP E82540/E82550/E82560 Series |
2403293_005975 2403321-000078 |
1.7.X |
HP LaserJet Managed MFP E72525/E72530/E72535 Series |
2403295_006000 2403321-000077 |
1.7.X |
4.0
HP PageWide Pro Managed MFP 477, 577, 57750 |
1629F (VR 1.2) 1629F |
1.7.X |
HP PageWide Color MFP/Flow MFP 586 |
2307849_000011 2308209_000569 2405129_000066 2308216-001092 |
1.7.X |
3.0
HP MFP/Flow MFP M630 |
2303714_233000 041 2308209_000571 2405129_00040 2308216001076 |
1.7 |
HP Color MFP/Flow MFP M680 |
2302786_433708 2302963_436072 2308209_000574 2405129_000042 2308216_001078 |
1.6.3, 1.7 |
HP PageWide Color MFP E58650 |
2308216-001092 |
1.7.X |
HP PageWide Color Flow E58650 |
2308216-001092 |
1.7.X |
HP X585 MFP group |
2302908_435002 |
1.6.3, 1.7
HP MFP S956dn |
H1.02.o1.00 |
H1.03.R2.00 |
HP Color MFP S970dn |
H1.03.S1.00 |
HP Color MFP S962dn |
H1.03.S1.00 |
HP Officejet Pro x476dn MFP |
1409A |
1.7, 1.7 Pro |
HP Officejet Pro 276dw MFP |
1416B |
1.7, 1.7 Pro |
HP LaserJet MFP M725 |
2302908_435014 |
1.6.3.2, 1.7 |
HP Color LaserJet flow MFP M880 |
2302908_435005 |
1.6.3.2, 1.7 |
HP Color LaserJet flow MFP M830 |
2302908_435011 |
1.6.3.2, 1.7 |
HP Color LaserJet flow MFP M577 |
2306272_536017 |
1.7.1 |
HP Color LaserJet flow MFP M527 |
2306273_536016 |
1.7.1 |
2302908_435006 |
1.6.3.2, 1.7 |
LaserJet M775 MFP |
2302908_435017 |
1.6.3.2, 1.7 |
LaserJet Flow M575 MXP |
2302908_435018 |
1.6.3.2, 1.7 |
LaserJet Flow M525 MXP |
2302908_435018 |
1.6.3.2a, 1.7 |
ScanJet 8500n |
2302829_434645 |
1.6.3.2, 1.7 |
ScanJet 7000n |
2201075_229185 |
1.6.3.2 |
Color LaserJet CM 4540 MFP |
2302908_435001 |
1.6.3.2, 1.7 |
Color LaserJet CM 3530 MFP |
50 |
53.231.6 |
1.6.3.2, 1.7 |
Color LaserJet CM 6049 MFP |
40 |
52.252.2 |
1.6.3.2 |
Color LaserJet CM 6040 MFP |
40 |
52.252.2 |
1.6.3.2 |
Color LaserJet CM 6030 MFP |
40 |
52.252.2 |
1.6.3.2 |
Color LaserJet CM 4730 MFP |
20 |
50.282.0 |
1.6.3.2 |
LaserJet M9059 MFP |
20 |
51.252.1 |
1.6.3.2 |
LaserJet M9050 MFP |
20 |
51.252.1 |
1.6.3.2 |
LaserJet M9040 MFP |
20 |
51.252.1 |
1.6.3.2 |
20 |
48.301.7 |
1.6.3.2 |
LaserJet M5035 MFP |
20 |
48.301.7 |
1.6.3.2 |
LaserJet M3035 MFP |
20 |
48.301.7 |
1.6.3.2 |
20 |
48.301.7 |
1.6.3.2 |
20 |
48.301.7 |
1.6.3.2 |
