Removing a Custom View
You can remove a custom view by using the Server Administrator > Messages node.
Note: Important!Before you remove a custom view, verify that the view is no longer needed by anyone in the server environment.
To remove a custom view
Expand the Server Administrator tree.
Expand Messages.
Right-click on the custom view you want to remove. Select Remove from the drop-down menu. You are prompted to confirm that you want to delete the view.
Click Yes. The custom view is removed.
